Dell OptiPlex 3050 micro BIOS
  • pcconnect
    • May 2019
    • 72
    hi guys,
    can anyone fix the bios, please?
    no display, 2 amber and 5 white blinks.
    • 20921
    Re: Dell OptiPlex 3050 BIOS
    Originally posted by pcconnect
    hi guys,
    Is it a tower PC or micro,post your service tag .
    • hoaca388
      Badcaps
      • Jan 2022
      • 11741
      hi guys,
      OptiPlex 3050
      Service Tag: FFLL2S2
      • pcconnect
        • May 2019
        • 72
        micro one but sorted now, thanks for the interest
        • pcconnect
          • May 2019
          • 72
          Originally posted by hoaca388
          OptiPlex 3050
          thanks hoaca388, the first one worked fine. you are a star
          • tsvone
            • May 2024
            • 4
            • Moldova
            Hi guys,
            No display, 3 amber and 6 white blinks.
            Thanks.
            OptiPlex 3050 micro
            Service Tag: HJN6MM2​
            • hoaca388
              Badcaps
              • Jan 2022
              • 11741
              Originally posted by tsvone
              Hi guys,
              Thanks.
              OptiPlex 3050 micro
              OptiPlex 3050 micro
              • tsvone
                • May 2024
                • 4
                • Moldova
                hoaca388, thanks for your work. When I check your files I will write.
                • adamgouadma
                  • Jul 2017
                  • 184
                  • setif
                  hi
                  service tag ;F7GFMN2​
                  • tsvone
                    • May 2024
                    • 4
                    • Moldova
                    OptiPlex 3050 micro
                    Hello. Finally managed to flash the Bios. The power supply was missing and I had to look for a replacement. The first file was flashed successfully and the PC started. Thank you very much hoaca388​ for your help.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11741
                      Originally posted by adamgouadma
                      hi
                      Service tag : F7GFMN2
                      • adamgouadma
                        • Jul 2017
                        • 184
                        • setif
                        Thank you for your interest, but my friend entered the CV by mistake, and when I restored her BIOS, it did not work and only worked with the BIOS that she entered by mistake.
                        • shiriff47
                          • May 2018
                          • 43
                          • Algeria
                          can anyone help me, i have the same problem, i have Optiplex 3050 micro but it not working with any bios i've tried so many dumps with no luck i tried extracting from exe file also with no luck it only works with the bios of optiplex 3050 AIO and it gives me errors in startup like the fan is not working properly & the password jumper is not present, is there any solution.
                          This is the Bios that work but it's the Optiplex 3050 AIO
                            • 20921
                            Why did you even consider using the 3050 AIO bios ? .Even if it does partially work,it doesn`t mean that its right one,thats why you have all those errors. If you have the original backup post it.
                            • shiriff47
                              • May 2018
                              • 43
                              • Algeria
                              it came to me in this situation for repair, the customer gave me this backup and he said that this is the original backup
                              • etnkcxs
                                • Mar 2023
                                • 12
                                • Brazil
                                My desktop blink 3 amber 6 white leds on startup
                                Here is the bios bin
                                SN: CHW73N2
                                  SMDFlea commented
                                  Editing a comment
                                  Thread merged.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11741
                                SN: CHW73N2
                                CCCC
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11741
                                  SN: CHW73N2
                                  ZZZ
                                  • shiriff47
                                    • May 2018
                                    • 43
                                    • Algeria
                                    Can anyone help me ?
                                    • Chaminda4191
                                      Chaminda4191
                                      • Apr 2023
                                      • 24
                                      • Sri Lanka
                                      hoaca388 ​ thank you first File is working with no errors .........
                                      • mrrubik
                                        Dell Optiplex 7010 micro bad BIOS flash?
                                        by mrrubik
                                        Hi folks,
                                        I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                        After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                        Steps I took:
                                        1. Read BIOS with CH341a, verified hash twice
                                        2. Patched
                                        12-23-2024, 04:11 PM
                                        DELL OptiPlex 3050 OptiPlex 3000 i5-7500 Specification for Upgrade or Repair
                                        This specification for the DELL OptiPlex 3050 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3050 boardview and OptiPlex 3050 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                        09-12-2024, 03:44 PM
                                        DELL OptiPlex 3050 OptiPlex 3000 i3-7100T Specification for Upgrade or Repair
                                        09-12-2024, 03:36 PM
                                        DELL OptiPlex 3050 OptiPlex 3000 i3-7100 Specification for Upgrade or Repair
