hp prodesk 600 g6 SFF CLEAN ME
  • Arrow16
    • Apr 2022
    • 229
    • Philippines
    need help for hp prodesk 600 g6 SFF beeping sound no display
    need CLEAN ME bios file, TIA
  • bbanana
    Father Land
    • Oct 2021
    • 164
    • Vietnam
    Re: hp prodesk 600 g6 SFF CLEAN ME
    try
    • Arrow16
      • Apr 2022
      • 229
      • Philippines
      anyone can help, tnx
      • Arrow16
        • Apr 2022
        • 229
        • Philippines
        Originally posted by bbanana
        try
        thank you for this my frîend, but still beeping sound no display,
        • hoaca388
          Badcaps
          • Jan 2022
          • 11809
          New file.
          • Arrow16
            • Apr 2022
            • 229
            • Philippines
            Originally posted by hoaca388
            New file.
            thank you ill try this one
            • ASB
              • Dec 2020
              • 133
              • Pakistan
              Need help to fix/ repair corrupt bios oh Hp 600 G6 SFF. I tried bios from post#5, and it worked but there are 2 problems. When I plug in the power cable and press the power button, the PC turns on and then turns off after a few seconds. Press the power button again and it shows the display. Another problem is that it shows FINAL STEP OF BIOS UPDATE IS IN PROGRESS after every power on. I updated the bios to the latest version but it didn't work. The casing is without the label so I can't provide the serial number.
              • hoaca388
                Badcaps
                • Jan 2022
                • 11809
                HP ProDesk 600 G6 Small Form Factor PC (9AW69AV)
                • ASB
                  • Dec 2020
                  • 133
                  • Pakistan
                  No display
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11809
                    No display
                    Impossible.Review your process.
                    • ASB
                      • Dec 2020
                      • 133
                      • Pakistan
                      I reprogrammed the IC with the bios in post#8. PC gives 3-2 beeps without the RAM but with RAM there is no display and PC turns off after some time as it does with the original bios. I have tried cleaning its ME region but same problem. Your bios in post#5 worked but have 2 issues which I have mentioned. Can you please provide the main bios and EC bios copied from a working PC?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11809
                        I don't have the bios you need.
                        • ADA_S
                          • Aug 2023
                          • 5
                          • Romania
                          Hello! I have HP ProDesk 600 G6 SFF, after deleting the bios password, this error appears <hp endpoint security controller problem>. Can somebody help me​?
                          • ASB
                            • Dec 2020
                            • 133
                            • Pakistan
                            I have a Hp 600 G6 SFF motherboard with corrupt bios. I tried to fix it's original bios but it didn't work so I edited and used another bios. Everything is ok but it's ETHERNET port is not working. I even replaced the GBE region but no use. I have faced the same problem in another Hp 600 G6 SFF motherboard after using this bios so it's definitely bios problem. Kindly help to solve this issue. There is no label on the casing so I can't provide the serial number.
                            • ASB
                              • Dec 2020
                              • 133
                              • Pakistan
                              Someone please help to fix this issue.
                                • 21001
                                Try MAC address tools https://www.badcaps.net/forum/troubl...60#post1465160
                                  HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                  This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                  09-12-2024, 02:30 PM
                                  HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                  HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                • Citymin
                                  by Citymin
                                  S/N : 5RNK9FFT70...
                                  08-05-2025, 05:12 AM
                                • Forest79
                                  by Forest79
                                  However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                  07-23-2023, 07:39 AM
