m.s ssd ATA SATA PASSWORD
  • musanide
    JQUB
    • May 2020
    • 86
    • zambia
    Anyone with a software for removing password from a m.2 ssd ata security lock
  • AAAC
    • Jan 2020
    • 458
    • Mexico
    Re: m.s ssd ATA SATA PASSWORD
    If this M.2 SSD drive was originally installed/locked in a Dell laptop, most likely a master password can be calculated. Provide more information about the laptop model where this M.2 SSD drive was installed, if that's not possible, then look at the SSD drive labels.
    • DynaxSC
      GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
      by DynaxSC
      I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
      There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
      The board is generally working now, all PCIe ports are working, Windows installs normally.
      However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
      The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
      03-10-2025, 12:27 PM
    • Nopslide
      HP Omen 15-dh0052nf power-on & bios password
      by Nopslide
      Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
      My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
      Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
      04-01-2024, 04:27 PM
    • questore
      HOW TO: Tutorial for removing Lenovo x390 yoga bios password
      by questore
      Hi Guys,
      I thought I write you a tutorial on how to remove your bios password from your lenovo x390 yoga.
      Steps:
      1. Get an EC programmer and read the EC firmware.
      2. Back up your working EC file !!! (on this modell EC stores all hardware infos and you cannot replace it with others)
      3. In your EC firmware file find all of these ranges with a hex editor and replace them with 00:
      !!!!!! IMPORTANT THAT YOU ONLY MODIFIED THE SPECIFIED RANGES AND NO MORE.
      (I have used HxD Hex editor FREE for this since I found that it is easy to replace ranges)
      0x36000...
      10-13-2025, 11:30 PM
    • SoheybB
      I need help with removing admin password from BIOS, please. HP-Specter-x360 13-0054na.
      by SoheybB
      I am very new to the BIOS scene and this is my first time doing this, so far:
      1. I have dumped the bin file and verified it using a CH341 (not with the clip) and AsProgrammer.
      2. I opened it using two different Hex Editors:
        1. HxD.
        2. ImHex.
      3. I have looked online for info/tutorial on similar models (couldn't find anything for the exact model), and the Strings/Hex Values to search i found count find the password block
      4. I tried comparing the dumped file and a black BIOS from HP website for the exact model, there were to many differences it would take me ages to go through
      02-27-2025, 04:18 PM
    • outsider
      Panasonic FZ-G1 MK5 - BIOS password returning
      by outsider
      Hello
      I removed the BIOS password thanks to the help of one of the friends of this forum.
      https://www.badcaps.net/forum/troubl...61#post3637661
      The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
      06-17-2025, 12:51 AM
