Board picture Sapphire Pulse Radeon RX5600 XT
AMD Radeon R9 290 / R9 380 / R9 390
The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...-
Channel: Schematics and Boardviews
by nosfayHello,
I got a SAPPHIRE NITRO+ RADEON RX 570 4G that has no picture.
I see no dmg on the board.
Fans and RGB are working.
I can see the card on Windows with an other GPU, but with an error in device management.
When I try to install last driver, it freeze.
I've tried to boot on Arch linux to do a meme test, and it freeze at boot.
Here is my resistance measurements :
Vcore seems low. What can I check next ?
Thanks...10-31-2024, 07:08 PM -
Thermal pad thickness for various laptop GPU / Graphics Cards
ASUS Dual RTX 2070 OC 8GB
ASUS ROG STRIX RTX 3080 OC
ASUS ROG STRIX RTX 3090
ASUS TUF Gaming RTX 3080 OC Edition
ASUS TUF GTX 1660 S-O6G GAMING
EVGA RTX 3060 Ti XC GAMING 8GB
EVGA RTX 3060 XC GAMING 12GB GDDR6
EVGA RTX 3080 FTW3 ULTRA GAMING
EVGA RTX 3080 TI FTW3 ULTRA GAMING
EVGA RTX 3090 XC3 ULTRA GAMING 24GB
Gainward RTX 2080 Phoenix GS Specs
Gainward RTX 3070 Phoenix 8GB
Gainward RTX 3080 Ti Phoenix
GIGABYTE AORUS RTX 3080 MASTER 10G
by MonkeydBrianHi i have a SAPPHIRE PULSE Radeon RX 570 gpu that when power on it doesn't get get detected by bios and fans spin at max rpm.. when i checked the bottom pci e section of the card the 4th pin from the right is short. i can find where it leads to to find solution
AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...-
10-01-2024, 01:07 PM -
- Loading...
