SAPPHIRE PULSE Radeon RX 570 8GB 3.3 short to ground
  • MonkeydBrian
    • Oct 2021
    • 17
    • south Africa
    Hi i have a SAPPHIRE PULSE Radeon RX 570 gpu that when power on it doesn't get get detected by bios and fans spin at max rpm.. when i checked the bottom pci e section of the card the 4th pin from the right is short. i can find where it leads to to find solution
  • MonkeydBrian
    • Oct 2021
    • 17
    • south Africa
    Re: SAPPHIRE PULSE Radeon RX 570 8GB 3.3 short to ground
    Originally posted by MonkeydBrian
    Hi i have a SAPPHIRE PULSE Radeon RX 570 gpu that when power on it doesn't get get detected by bios and fans spin at max rpm.. when i checked the bottom pci e section of the card the 4th pin from the right is short. i can not find where it leads to to find solution
    can someone please assist if they have an idea where i should look as i don't have a voltage injector
    • stormanimal83
      • May 2014
      • 74
      a solution could be to look for a boardview of this card wich i already did now. it isnt online here. you could look for a boardview of a similar card to find out whats wrong with it.
      • Aliencomputres
        • Aug 2019
        • 208
        • România
        What brand ?
        I have two of this MSI
        • MonkeydBrian
          • Oct 2021
          • 17
          • south Africa
          Nitro sapphire pulse
            AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
            The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
            10-01-2024, 12:46 PM
            Thermal pad thickness for various laptop GPU / Graphics Cards
            ASUS Dual RTX 2070 OC 8GB
            ASUS ROG STRIX RTX 3080 OC
            ASUS ROG STRIX RTX 3090
            ASUS TUF Gaming RTX 3080 OC Edition
            ASUS TUF GTX 1660 S-O6G GAMING
            EVGA RTX 3060 Ti XC GAMING 8GB
            EVGA RTX 3060 XC GAMING 12GB GDDR6
            EVGA RTX 3080 FTW3 ULTRA GAMING
            EVGA RTX 3080 TI FTW3 ULTRA GAMING
            EVGA RTX 3090 XC3 ULTRA GAMING 24GB
            Gainward RTX 2080 Phoenix GS Specs
            Gainward RTX 3070 Phoenix 8GB
            Gainward RTX 3080 Ti Phoenix
            GIGABYTE AORUS RTX 3080 MASTER 10G
            02-09-2024, 08:08 AM
          • playit
            450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
            by playit
            hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
            09-02-2023, 02:43 AM
            AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
            The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
            10-01-2024, 01:07 PM
            AMD Radeon RX 470 / RX 580 Schematic & Board View
            The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
            10-01-2024, 12:52 PM
