can anyone ID this gateway p4D-66I motherboard please
  • psicobra
    • May 2022
    • 8
    Hi guys i was given this gateway p4D-66I it is a 486 dx2 66mhz with 8MB ram and a 425MB hdd. apart from the bios battery being dead which i replaced the machine works perfectly !!!!!
    How ever i would really like to upgrade the RAM possibly the CPU to a dx4 100 but i cannot find any information on the motherboard can any one help so i can get a manual thanks.
    PSI
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: can anyone ID this motherboard please
    https://www.ultimateretro.net/en/motherboards/10127
    • psicobra
      • May 2022
      • 8
      Re: can anyone ID this gateway p4D-66I motherboard please
      that's awesome thank you.
      PSI
      • psicobra
        • May 2022
        • 8
        aby idea where i can get the jumper settings from please.
        PSI
          • 21845
          PSI
          https://www.vogons.org/viewtopic.php?t=62736
          • glovecaps
            by glovecaps
            11-25-2024, 04:23 PM
          • Archimedes
            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
            by Archimedes
            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
            Fans are spinning. Blindly could install windows11 and got the device manager...
            07-30-2024, 05:14 PM
          • dragon3x
            by dragon3x
            power on.
            Here are some examples :
            switching supply area).
            than 6.3 V.)
            03-21-2025, 02:46 PM
          • dhenion
            Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
            by dhenion
            I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
            The original board was:
            ASUS X510UNR REV 3.0 A
            The replacement board is:
            ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
            It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
            01-30-2024, 01:45 PM
          • Mess
            Motherboard diagnostic beginner advice
            by Mess
            To save you some time: the most important bits are in bold.
            Some further examples/explanations or to the side & in grey - you can probs skip them if it's TLDR for you. Sorry, I've got ADHD & tend to over-explain stuff - just like I'm doing right now 😅 Briefness is for poets not me 🙈
            Please help!! 🎶I'm just a girl in a world that wants to scam me out of lots of money for any tech stuff/repairs 🎵 Seriously tho, I'm poor&I can't afford to get laptop diagnosis, especially if it ends up needing a new motherboard. Where I live, all the tech shops are run by very...
            09-12-2024, 07:02 PM
