Missing voltage on ZOTAC GTX 1050 TI 4gb coil - need schematic
  • fab13
    • Dec 2021
    • 109
    • France
    Hello to all,
    I have a missing voltage on this ZOTAC GTX 1050 TI mini card (circled in blue)
    I have all my other voltages strangely but the missing one goes up to 0.04 V and measured in Ohm 45 Kohm I find that really high and I expected much less than that.
    0 SHORT circuit on the rest of the board
    GPU heating and voltage at the coils 0.80 V which is normal for this type of card logically.
    Without a schematic it's quite complicated and long to look for.
    Do you have an idea?
    I checked all my components seems present and checked in 2 times with the microscope and no missing.
    With the thermal camera nothing heats up except a 2 Kohm resistor (noted 30B) but I find well my 12 V on one side
    Many thanks in advance,
    If you need more pictures I will send you some if necessary
  • fab13
    • Dec 2021
    • 109
    • France
    Re: Missing voltage on ZOTAC GTX 1050 TI 4gb coil - need schematic
    • ductranvinh
      • Dec 2021
      • 123
      • Republic of Vietnam
      u need check some voltage level:
      12v,5v,3.3v,1.8v,1.05v boot, 0.9-0.8v gpu, 1.5-1.35v ram
      PC work for schemaltic:
      Mainboard: Gigabyte Z68XP-UD4
      CPU: I3-3240
      Ram: 16Gb
      Graphic Card: GTX 1050Ti zotac 4Gb Mini
      SSD: 120Gb
      HDD: 2Tb
      • fab13
        • Dec 2021
        • 109
        • France
        I was able to test the rest of the system, I have my voltages up to the GPU.
        This coil L11 is surely the missing 1V voltage.
        I could point with the probes and see where it is powered and it seems that it is powered by a Q4 transistor which is probably a PNP transistor (Test positive probe of the Base and
        black probe on Transmitter = blocking
        Test positive probe from Base to Collector = blocking
        Positive probe test from Collector to Base = on, i.e. approximately 0.610 V
        So I replaced by an equivalent transistor and I could find 1,09V
        Now when I turn on the card the display port is now recognized but black screen and HDMI
        Maybe the wrong transistor installed? or insufficient voltage on this L11 coil? I could measure now 1.09V
        I am doing wrong?
        See the pictures
        Thanks a lot =D
        • ductranvinh
          • Dec 2021
          • 123
          L11 is coil supply voltage for Fan! Haiz! First check and find 1.8v coil
          CPU: I3-3240
          Ram: 16Gb
          SSD: 120Gb
          HDD: 2Tb
          • ductranvinh
            • Dec 2021
            • 123
            Same same 70% and good luck
            CPU: I3-3240
            Ram: 16Gb
            SSD: 120Gb
            HDD: 2Tb
            • fab13
              • Dec 2021
              • 109
              • France
              Thank you very much, that's the 12 V Fan
              The 1.8 V is present on the coil
              And the fan is rotating at maximum from the start
              Or do I have to look at another Enable signal?
              Display port detected by the screen but not the HDMI and black screen.
              I have my 1.5V VMEM and 0.80V on all GPU phases
              Also my 3.3V on the bios powered correctly as a whole.
              I have no idea lol
              • crot69
                asus x453sa missing all voltage except 19v and charging pin
                by crot69
                Hi, my friend have this laptop
                Before all voltage missing, im already repair this laptop 3x (i have 3 of this laptop and all of them dead, can't be repaired because dead CPU and other component due unknow chips, why always asus laptop have this issue).
                1st repair it short at 3vsus (dead low side mosfe and short caps)
                2nd repair short at CPU Vcore mosfet (low side)
                3rd repair 12v missing (only 1.2v but it can run bios and hdd not detected because 3vs missing).
                and then after 3x enter BIOS it blank then dead (all mosfet buzzing, 12v still missing)
                11-23-2022, 09:51 PM
              • T4H
                RTX 2080 ti (Zotac - triple fan) - No video output / Vcore / Vmem missing
                by T4H
                I have an RTX 2080 ti (Zotac - triple fan) with no video output.
                So far I have measured the following:
                • PS_FBVDD_PH3_SW = 40 ohm to ground (Micron ICs) - Memory should be fine right?
                • 12V power rail present
                • 3.3V power rail present
                • 5V power rail present
                • 1.8V power rail present
                • Vcore power rail missing --> PS_NVVDD_VREF is present. (from uP9512P / U812)
                • Vmem power rail missing --> Not there because Vcore power rail is missing.
                Any idea? I have already tried to flash the BIOS chip (backup got created) - sadly no changes.
                Source: https://www.techp...
                08-19-2023, 08:14 AM
              • chbalnuweit
                HP 17-cn0234ng - RAM and VCORE voltage missing
                by chbalnuweit
                I got an HP 17-cn0234ng and I am hitting a wall diagnosing it.
                When I first got it, it wouldnt turn on at all and no lights were active.
                I found a shorted capacitor on the 3.3V powerrail near the lid sensor. Once I removed the shorted capacitor, the power and charging light on the DC connector started working and the Laptop reacted to the powerbutton.
                When I press the powerbutton, current consumption goes up to about 50mA and just stays there. Chipset and 3.3V regulator getting a bit warm under thermal camera, but not really noticeable...
                03-07-2025, 05:21 AM
                Gigabyte Sabre 15-1050-801 Notebook Specification for Upgrade or Repair
                This specification for the Gigabyte Sabre 15-1050-801 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15-1050-801 boardview and 15-1050-801 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 11:44 AM
                Gigabyte Sabre 17-1050-801 Notebook Specification for Upgrade or Repair
                This specification for the Gigabyte Sabre 17-1050-801 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 17-1050-801 boardview and 17-1050-801 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
