EVGA nVidia 8500gt
  • merkin
    • May 2010
    • 57
    EVGA nVidia 8500gt
    Started to get Blue screens which blamed the nvidia driver.
    Also blocks of pixels and individual pixels would change colors creating a scrambled mosaic before the bluescreen would occur.
    Some research brought me here.
    There are 5 caps labled as follows: (Fluke 87V cap measurements)
    (1x) 7D
    OCR
    330 (431)
    16v
    (3x) FZ75
    1500 (1745, 1752, 1738)
    6.3v
    (1x) FZ73
    1000 (1174)
    6.3v
    I am sure there are some tolerances, but are these bad?
    Found replacements for the 4 caps with 6.3v ratings. However the closest I found for the 16v cap is a rubycon 330uf 35v and rubycon 470uf 16v. Which of the two rubycon are the best replacement? Is it better to stay close to capitance or voltage? Or should I keep looking through my junk for equal capitance and voltage?
    Thanks in advance, merkin
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: EVGA nVidia 8500gt
    dont bother about the caps. the GPU itself is toast.
    nvidia had a huge fuckup with the G84/G86 GPUs (that includes everything from 8400GS to 8600GTS)
    once you see a pixel mess, driver stop errors/bluescreens, or random freezing, that GPU is done for..
    http://www.theinquirer.net/inquirer/...ia-g84-g86-bad
    http://www.theinquirer.net/inquirer/...misery-deepens
    http://www.theinquirer.net/inquirer/...sets-defective
    • Scenic
      o.O
      • Sep 2007
      • 2642
      too late to edit.
      OCR sounds like Lelon OCR polymer caps.
      FZ is Sacon FZ = pure junk.. replace on sight.
      (if you're gonna try your luck with the caps)
      edit: if you registered your card you could also try a RMA
      http://www.evga.com/support/warranty/
      • seanc
        • Nov 2008
        • 1319
        If the caps aren't blown and you can't get an RMA:
        Remove all heatsinks, capacitors if possible and melty bits. If you can't remove the caps, cover in layers of tinfoil.
        Prop the four corners on some oven proof dishes, with the processor side up, put it on an oven tray and bake it for 8ish minutes @ 200˚C.
        VERY GENTLY take it out and let it cool for an hour, then test.
        If it works, you've got a card for a bit longer, if it doesn't just throw it in the bin like you were originally going to do.
        I cured an 8800GTX this way, not given it much abuse, but it definitely does work now.
        • merkin
          • May 2010
          • 57
          My part number ends in -LR.
          Only 2 year warranty and this card is at least three years old.
          So basically i need to reflow the BGA's?
          Did this with the xbox 360. I used standoffs and put the board on a flat aluminum cook top with temp controls. Then used a painters heat gun on the top of the board. Shot some liquid flux underneath the BGA chips with a hypodermic needle. My fluke 87V measures the temps quite well.
          Thanks everybody ill keep ya updated.
          BTW no one answered my question about the replacement caps in the OP.
          • seanc
            • Nov 2008
            • 1319
            Have they blown, yes or no?
            • merkin
              • May 2010
              • 57
              No
              • yyonline
                • Jul 2009
                • 692
                What series Rubycon did you find for the 6.3V caps? Sacon FZ should be replaced with MBZ or better as per the specs. That's not to say the specs are accurate, but if it was designed for a cap with those specs, best to replace it with something with similar specs, but more reliable. Rubycon MBZ/MCZ will work fine. Other Rubycon series are likely not low enough ESR.
                OCR is a polymer cap. Replace with something like Sanyo OSCON, Chemicon PS/PSA/PSC, or Nichicon LF/LG, FPCAP.
                Topcat carries OSCON:
                https://www.badcaps.net/store/produc...products_id=78
                The others can likely be found at Digikey and Mouser.
                All that said... I'd expect this is not a capacitor issue, and agree with what has been said earlier. Sounds like your GPU is fried. Blue screens, artifacts, and random patterns are the signs of this. Not uncommon for GeForce 8 series cards. Then again, caps usually aren't too expensive, so it can't hurt to try.
                • piernov
                  NVidia bumpgate
                  by piernov
                  Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                  Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                  May complete this post at a later date with more details.
                  Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                  03-27-2021, 10:34 AM
                  NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                  The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                  10-02-2024, 08:52 AM
                  NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                  The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                  10-02-2024, 07:51 AM
                  NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                  The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                  10-01-2024, 01:54 PM
                  Thermal pad thickness for various laptop GPU / Graphics Cards
                  ASUS Dual RTX 2070 OC 8GB
                  ASUS ROG STRIX RTX 3080 OC
                  ASUS ROG STRIX RTX 3090
                  ASUS TUF Gaming RTX 3080 OC Edition
                  ASUS TUF GTX 1660 S-O6G GAMING
                  EVGA RTX 3060 Ti XC GAMING 8GB
                  EVGA RTX 3060 XC GAMING 12GB GDDR6
                  EVGA RTX 3080 FTW3 ULTRA GAMING
                  EVGA RTX 3080 TI FTW3 ULTRA GAMING
                  EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                  Gainward RTX 2080 Phoenix GS Specs
                  Gainward RTX 3070 Phoenix 8GB
                  Gainward RTX 3080 Ti Phoenix
                  GIGABYTE AORUS RTX 3080 MASTER 10G
                  02-09-2024, 08:08 AM
