Hello, some components have been burned in my graphics card, but I don't know exactly what they are, they are from LB16 to LB19, the description of the boarview is "220/8/3A/S", I would appreciate if someone could tell me which component I should buy and its value. All the best
Gigabyte GTX 1080 mini
Re: Gigabyte GTX 1080 mini
Possibly 220nH probably doesn't make a lot of difference they are only 12v input filtering, a piece of wire will do until you can ascertain the board is fixable.
The real question is why are they blown? Most probably a shorted output stage U525-U528 failing a visual inspection to identify the faulty drmos, you can measure GH pin 6 on them in resistance mode, the shorted one will probably have a shorted gate also, maybe also check GL pin 36 -
The U525 was shorted, I have already removed it, for now there is no short on any of the inputs when . What I needed to know is if the LBs were resistors or inductors, so you tell me they are 220nh inductors, I will buy the components and see if it works when I have everything soldered, thanksComment
i have a gtx1080mini itx gigabyte.. this card don't see 12v 8pin connector.Comment
Thermal pad thickness for various laptop GPU / Graphics Cards
ASUS Dual RTX 2070 OC 8GB
ASUS ROG STRIX RTX 3080 OC
ASUS ROG STRIX RTX 3090
ASUS TUF Gaming RTX 3080 OC Edition
ASUS TUF GTX 1660 S-O6G GAMING
EVGA RTX 3060 Ti XC GAMING 8GB
EVGA RTX 3060 XC GAMING 12GB GDDR6
EVGA RTX 3080 FTW3 ULTRA GAMING
EVGA RTX 3080 TI FTW3 ULTRA GAMING
EVGA RTX 3090 XC3 ULTRA GAMING 24GB
Gainward RTX 2080 Phoenix GS Specs
Gainward RTX 3070 Phoenix 8GB
Gainward RTX 3080 Ti Phoenix
GIGABYTE AORUS RTX 3080 MASTER 10G
Channel: Schematics and Boardviews
02-09-2024, 08:08 AM -
by repairboi31Hi everyone, i am a student i'm looking for your advice on my laptop.
Gigabyte Aorus 15P-KD (11th gen intel)
Motherboard: GA-RX5LKD REV 1.2
Model Number: RX5L
11800H SRT3
RTX 3060 6GB
HM570 SRKMA
I showed my computer to 3 notebook technician and gigabyte service.
Gigabyte service doesn't find any way to fix it. They never had schematics for this laptop because they never had any document agreements with gigabyte company.
1st technician said CHIPSET is hot we need to replace. I bought the chipset but... -
by ss45hi folks. i have gpu with shorted here. sorry if i posted i the wrong sub..
d33 was shorted and has been removed. if anybody has one at hand and has the free time, would it be too much trouble to take measurement of the diode. of course i can make makeshift diode using 2 discrete diodes, but i cant figure out which direction cathode and anode. searching online with sot 23 diode as keyword giving several different pinouts. i am afraid trying each possibilities one by one might damage the card further....
so if anyone willing to help, i would be grateful...-
05-13-2020, 08:50 AM -
by foshlandHi to all, I have a 970 mini that has Q503 leg 2 (IFP_IOVDD (backdrive prevention)) shorted to ground, If I inject 2 volts, only GPU heats a little (2 Amp draw), can I assume its a dead GPU?? or should look somewhere else? It came with some capacitors and resistors burnt from the analog part of the DVI (VGA output) and they are open, not shorted.
If I connect it to the PC, it heats reaching 60 degrees with no heatsink in 30 seconds, It isnt recogniced by the PC, so doesnt have meassured another voltages. Mosfets looks good and visual inspection is OK.
Attached schematics,...12-07-2021, 10:23 PM -
by kappamaxI Need bios of "Gigabyte 1660 super mini itx".
i lost my serial.
V19120-1
2/AX/KJ7864 01073 V19119-2 - PCB SN
Thank a lot...-
- Loading...
