MSI 1050 Ti - Recognized but no display
  • LupenWonse
    • Dec 2021
    • 19
    I have an MSI 1050 Ti 4GB OC Edition, that I am trying to repair.
    Here is my situation:
    • On the card all voltages seem to be present. I could not detect any issues.
    • When the card is installed booting with integrated graphics is no problem.
    • The card is detected correctly by GPU-Z
    • I can read and write BIOS without any problems.
    • I have already tried several BIOS versions but this did not change anything.
    • Installing Nvidia drivers when the card is installed in the system crashes Windows
    I am rather new GPU repair and have no idea how to proceed in this situation.
    Does anybody have ideas? How could I diagnose this card further?
  • Bozog
    • Jan 2022
    • 125
    Re: MSI 1050 Ti - Recognized but no display
    Quite likely a bad memory chip, see here for how to test them:
    https://www.badcaps.net/forum/showthread.php?t=84308
    • LupenWonse
      • Dec 2021
      • 19
      Thanks for the tip.
      I still haven't managed to run mats (some kind of Motherboard incompatibility I think.) but working on it.
      • LupenWonse
        • Dec 2021
        • 19
        I think I have finally managed to run MATS.
        The test shows all read errors on all chips. I do not really know how to interpret this results. Hopefully I am running these tests correctly.
        Would this mean that the memory controller is dead and therefore the GPU?
        Or could this be caused by something else? (wrong BIOS??)
        Thanks for any suggestions.
        Code:
        mats version 400.184. Testing GP107 with 1 MB of memory starting with 0 MB.
        Read  Error Count: 1426432
        Write  Error Count: 0
        Unknown Error Count: 0
        === MEMORY ERRORS BY SUBPARTITION ===
        SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
        FBIOA0    356608      0      0
        FBIOA1    356608      0      0
        FBIOB0    356608      0      0
        FBIOB1    356608      0      0
        Failing Bits:
          A000 A001 A002 A003 A004 A005 A006 A007 A008 A009 A010 A011 A012 A013 A014 A015
        A016 A017 A018 A019 A020 A021 A022 A023 A024 A025 A026 A027 A028 A029 A030 A031
        A032 A033 A034 A035 A036 A037 A038 A039 A040 A041 A042 A043 A044 A045 A046 A047
        A048 A049 A050 A051 A052 A053 A054 A055 A056 A057 A058 A059 A060 A061 A062 A063
        B000 B001 B002 B003 B004 B005 B006 B007 B008 B009 B010 B011 B012 B013 B014 B015
        B016 B017 B018 B019 B020 B021 B022 B023 B024 B025 B026 B027 B028 B029 B030 B031
        B032 B033 B034 B035 B036 B037 B038 B039 B040 B041 B042 B043 B044 B045 B046 B047
        B048 B049 B050 B051 B052 B053 B054 B055 B056 B057 B058 B059 B060 B061 B062 B063
        • LupenWonse
          • Dec 2021
          • 19
          Ok, my test setup was not working properly.
          You were completely right. I found the defective chip. Thank you very much for your help.
          • Megaquake
            • Feb 2022
            Can you guy help me identify a missing resistor on my MSI 4G 1050ti
            • Megaquake
              • Feb 2022
              r1034 in the first pic near the lock
              • Tiger14n
                • Feb 2022
                • 4
                hey bro, i have the same problem with a gtx 1060 6gb
                Code:
                FBIOA0   2726272      0      0
                FBIOA1   2729472      0      0
                FBIOB0   2731392      0      0
                FBIOB1   2732032      0      0
                FBIOC0   2726656      0      0
                FBIOC1   2722816      0      0
                Failing Bits:
                how did you find the defective chip? and have you fixed the gpu yet?
                • LupenWonse
                  • Dec 2021
                  • 19
                  Hi there,
                  I realized that my test setup was testing the integrated GPU and not the actual card. I used a MATS version which was setup to run blindly, disabled integrated GPU and re-run the test. Then I got a clear FAIL on one of the chips.
                  But no I still have not repaired the card since I do not have a replacement memory chip.
                  • benwaterson
                    • Aug 2008
                    • 202
                    • United Kingdom
                    I would have thought MATS would only try and test an nvidia gpu, which if it is the integrated one it was testing then surely that was intel/amd?
                    I might try this blind method on mine though to see if I get better results than read errors on all banks.
                    • Bozog
                      • Jan 2022
                      • 125
                      I always have to add -n 1 since I have on-board intel graphics, so:
                      Code:
                      ./mats -e 20 -n 1
                      • benwaterson
                        • Aug 2008
                        • 202
                        • United Kingdom
                        Code:
                        ./mats -e 20 -n 1
                        Yes that's the correct syntax to select a different GPU. Doesn't help with the errors unless it testing the wrong card and that card is an nvidia GPU as well afaik
                        • benwaterson
                          • Aug 2008
                          • 202
                          • United Kingdom
                          No luck for me using this method. Still read errors on all banks
                          • Tiger14n
                            • Feb 2022
                            • 4
                            Originally posted by LupenWonse
                            Hi there,
                            i guess thats not my issue, because i have tested a different GPU on the same setup and got 0 errors
                            • benwaterson
                              • Aug 2008
                              • 202
                              • United Kingdom
                              Did you manage to get any further with this? @Tiger14n
                                HP EliteBook 1050 G1 Notebook 1000 Specification for Upgrade or Repair
                                This specification for the HP EliteBook 1050 G1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 boardview and 1050 G1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP EliteBook...
                                09-06-2024, 07:02 AM
                                09-06-2024, 07:00 AM
                                09-06-2024, 07:07 AM
