Palit GTX 1050Ti short mosfet value 4C029 RFMOP
  • rodbautis
    • Jan 2022
    • 4
    • Philippines
    hello Please help ...
    any compatible value for this mosfet i cant find this exact value in my location.
  • rodbautis
    • Jan 2022
    • 4
    • Philippines
    Re: Palit GTX 1050Ti short mosfet value 4C029 RFMOP
    GPU status No power ...everytime i insert GPU on MObo the test rig cant On so 100% GPU short ... i found the mosfet short now GPU can on but no Display at all . any recomendation compatible mosfet value for this. 4C029 RFMOP
    • DrasticRepairs
      • May 2021
      • 23
      What's the resistance from the coil next to it to ground? If it's less than 20 ohms, the core is dead. Usually when the memory VRM shorts on nvidia GPUs, it kills all of the VRAM and the core.
      • rodbautis
        • Jan 2022
        • 4
        • Philippines
        thank you for Reply Bro ..
        now my problem is i dont have mosfet ...any link where can i get this mosfet 4C029 RFMOP .... i found on aliexpresss this mosfet but i dont know if this compatible
        NTMFS4C029NT1G
        Aliexpress
        • manuforti1314
          • Sep 2021
          • 44
          • United Kingdom
          NTMFS4C029NT1G
          Aliexpress
          If it was my card I would measure the resistance on the core as DrasticRepairs advised. If the core reistance was above the 20 ohms I would buy the chips linked from AliExpress. The RFMOP is just the manufacture/lot/date information.
          • DrasticRepairs
            • May 2021
            • 23
            Actually, that's not quite what I was saying. The rail that has the bad MOSFET is for the VRAM. The core will always fail short, and it's normal for a good gpu to be around 0.1ohms. So the only way to test for a core short is with voltage injection. In this case it's the memory that would be shorted. However, the memory controller in the gpu runs on the same voltage rail as the memory itself and is very sensitive to overvoltage. So 99% of the time, when the memory regulator shorts, the gpu is killed.
            The thing that needs to be checked is VMEM (memory voltage rail). If it's shorted, the core is dead.
            If the card is turning on, and shows a picture, then the MOSFET really is all that's needed. Aliexpress or eBay are the best options. You can find some comparable chips, but it takes quite awhile to check all of the specs to be sure it's compatible.
            • rodbautis
              • Jan 2022
              • 4
              • Philippines
              Thank you for hellp .. i rcv my mosfet and Put on GPU ....
              GPU got image for few Secs then sudenly Mosfet Burn again.
              • DynaxSC
                • Apr 2021
                • 457
                • Poland
                Hi, that means that you have cured the symptom not the root cause. Check the resistance as DrasticRepairs suggested. The burned mosfet could mean that the other mosfet is already somewhat defective, or the phase control is not functioning correctly due to some error in the VRM network and it comes to a overlap during phase swithing (both mosfets are conductive in some time), or you have some other short on the memory power consuming network (eg. a defective but not fully shorted capacitor). If GPU and memories are still alive the best (and probably the most effective solution) would be to take off GPU and memories, and then test VMEM with voltage injection if some capacitor shorts. Then you can go with the memory injected voltage somewhat higher than nominal, but no more than 2.5V, thats the caps nominal max. voltage. Then you can also experiment with changing both mosfets, VRM controller, etc. and confirm that GPU/memories are not the root cause. The VRMs usually run normally w/o GPU/Memories on board.
                Pls write which mosfet burns - high side or low side. If lowside there is some chance, that GPU and memories have survived, what could be due to the picture has been generated for a few seconds. You can also do the voltage injection w/o taking off GPU/Memories, but then you can't go higher as memory nominal voltage (probably 1,5V ???), and then when "experimenting" with VRM network the risk for GPU/Memories to be destroyed is quite high.
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  Usually a good idea to replace MOSFET driver/buck controller at the same time, and check gate resistor if it exists.
                  Also, no way to know if replacement parts from Aliexpress are any good, large amount of garbage on there…
                  • aaronkatrini
                    DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
                    by aaronkatrini
                    I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
                    - Put the card in my testing motherboard and start running Heaven benchmark
                    - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
                    - Try to start it again and I get a slight move from the PSU fan - a clear short
                    - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
                    - Put the...
                    05-18-2025, 04:18 PM
                  • jm942
                    Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                    by jm942
                    My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                    I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                    I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                    I did voltage injection on the cpu with 0.7V and i have a current...
                    07-11-2024, 05:11 AM
                  • joshAU
                    Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                    by joshAU
                    Hi all.
                    This notebook was showing no signs of life.
                    I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                    However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                    If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                    I tried replacing the MOSFET with a new one, but again no voltage on the...
                    05-29-2024, 12:33 AM
                  • dqtech
                    Asus X455L Short Mosfet
                    by dqtech
                    I got this laptop from friend with problem short 19v....when i check this 2 mosfet getting short...i remove that mosfet and confirm that mosfet is short...
                    and check that 2 capacitor PC9009 and PC9004 pad is also short...already check where that capacitor goes and came from but cannot find the main problem...please help
                    08-09-2022, 08:53 PM
                  • vexarvf1s
                    Acer: No power after first MOSFET no short? Looking for guidance.
                    by vexarvf1s
                    Looking for guidance in tracking down missing main power rail.
                    I have an Acer that I am working on. It runs on the battery, but does not charge. I changed the power adapter and same thing battey not charging, and continues to discharge. So I opened the computer and started looking for the problem to fix.
                    First thing I checked is if the power form the charger is getting to the mainboard. I found that 19V is going all the way to the first MOSFET. So DC jack is fine. However I do not have power past the first MOSFET.
                    So checked for voltage on the gate of the first MOSFET and...
                    05-13-2023, 07:55 AM
