RX470 8GB FE freezes
  • foshland
    • Jan 2017
    • 122
    • Spain
    Hi to all, I have a RX470, the one with only a 6 pin connector that is detected fine, Matts says no memory error but it freezes in windows and gives green or blue or red screen after installing drivers. I know that card is a huge Watts consumer, but in this PC I have tested other hungry ones and they run OK.
    I have read a lot about possible problems due to PCIex over watt ussage, but all that info is from years ago, I think many problems were solved with new drivers, but I have the most recent ones and this card allways freezes.
    Any ideas? thanks a lot
  • foshland
    • Jan 2017
    • 122
    • Spain
    Re: RX470 8GB FE freezes
    Well, after some test, I have tried diferent Bios, and modifiying them with polaris editor, but nothing turns it ok.
    In polaris editor I tried to change the voltages of the ram when it goes faster, cause it goes to 1V when it crashes.
    The fact is that all voltages (ram and core) goes up to 1V when it freezes, before that they stay at 0.9V
    Have tried many times Tserver at diferent configurations (at the first post I said Matss, but was refering to Tserver) and all of them it says there is no error and card doesnt freezes
    Dont know what more to try
    Any ideas?
    • grosseader
      MSI B450 Gaming Plus Max - freezes randomly
      by grosseader
      Hello everyone, i got this mobo for long time, now i decided to rearrange some hardware and build a office pc, but 1 week so far, this motherboard drives me crazy.
      What is the issue:
      PC freezes randomly. While loading win, while installing win, while in windows , and just once did it while in bios.
      Hardware:
      MSI B450 Gaming Plus Max , MSI A320m A-pro
      BIOS : 7B86vHG - latest
      CPU: Ryzen 3 1200, 3200G , Ryzen 5 3500x, Ryzen 5 5500
      GPU: Vega 7 in 3200g and MSI 1060 6GB
      RAM: 2x8 ADATA spectrix 3000 , 2x8 SiliconePower 3200
      01-30-2023, 03:24 PM
    • hinisa
      Xiaomi router freezes at boot after re-capping
      by hinisa
      I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
      When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
      After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
      Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
      07-08-2023, 05:58 AM
    • Artakozu
      Xfx RX470 - Missing components
      by Artakozu
      Hi, I'm new to this forum.
      I recently bought a damaged XFX RX470 for around $10-12 USD. As you can probably see, I believe the only issue is some missing components, likely due to a scratch or a fall.
      Can anyone help me confirm which components are missing, and specifically, tell me the value of capacitor C502?...
      05-20-2025, 06:26 PM
    • Tiwes
      RX470 / Vega 56 repair
      by Tiwes
      Hello everyone I've got lot of Gpus for good buck and I'm trying to repair them watched few videos and got pretty good understating of basic voltage rails etc.
      I came here for help with further diagnosing the problem which are occuring.
      1. Vega 56
      This card had blown mosfet on power stage 3 which took the doubler there aswell. Changed it from spare card. tried the card all voltage rails are present except the VCORE. On powerup it jumps to 0.9V and then drops to 0.
      2. Vega 56
      The same above things are happening but the difference is it was on power stage...
      05-29-2022, 06:35 AM
    • kuba2102
      Medion Erazer beast x25 freezes and resets only at low CPU usage
      by kuba2102
      Medion Erazer beast x25 62307 MSN 30031969 GM5ZGXW AMD version
      Hello. The laptop freezes and resets only at low CPU usage, practically at IDLE after a few minutes. There is no problem under a load, and I benchmarked it for over an hour. I noticed that one of the CPU coils was making whining noise at low CPU usage. I previously thought it was a BIOS problem, but updated BIOS and no change. I'm thinking of changing the CPU DrMos'es there are 5 of them all together. I have already swapped the DrMOSes first one with the last one (I desoldered them and soldered in swapping DrMos no.1 with...
      01-06-2025, 09:14 PM
