Strange resistance readings on Radeon RX6800 VRM
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I can't quite get my head around the resistance readings on this GPU
    On phase of Vcore VRM reads higher resistance than the others
    This 3 mins video shows exactly what I mean
    https://www.youtube.com/watch?v=NZR4otU77VE
    I can't think any way this could happen unelss one phase is not directly connected to the others, but is conetced via a low value resistance
    Can someone unconfuse me please
    Cheers
    Follow me on YouTube
    Learn Electronics Repair
    master hoarder
    • May 2008
    • 12168
    Re: Strange resistance readings on Radeon RX6800 VRM
    TBH, I'm not too familiar with these newer gen GPUs, so perhaps it is possible that this one phase is not connected to the others. Have you traced the MOSFETs for that phase to see if they are exactly connected like the MOSFETs on the other phases (and to the same controller)? I think that might be the first clue in telling if that's part of the GPU VRM or some secondary GPU VRM. I do agree that it's strange that only this one coil reads higher resistance, though. I'd expect to see at least another phase in parallel with it, if it was to be some secondary GPU VRM rail. On the other hand, if all of these phases were to be connected together, then the only way that higher resistance would be there is if the copper trace from the coil to the GPU chip has burned and gone high resistance... which I think would be highly unlikely.
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Hi Momaka
      Thanks. It shouldn't be too difficult to see if this phase goes to the same controller as the other phases, for example if there is an 8 phase VRM controller
      But I couldn't find a datasheet for the coil driver IC either so that does not exactly help
      Because this one phase still has a very low resistance to ground it also seems odd to me that it would be a singleton as you mentioned.
      I could just try powering the card up and measure the voltage on this and other inductors on the VRM - but I really would like to understand what I am looking at first.
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        OK I pretty much got to the bottom of this - at least I have a plausible theory for the odd resistance readings on the VRM
        The fault on this card appears to be elsewhere
        It's easier to watch than for me to explain in detail what I worked out
        https://www.youtube.com/watch?v=ooefNfC8Lxg
        Rich
          AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
          The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
          10-01-2024, 12:46 PM
        • Byte_76
          Faulty XFX Radeon RX6800 Merc 319. (Non-XT)
          by Byte_76
          I have an XFX Radeon RX6800 which allows me to boot into Windows but as soon as the drivers load, the screen turns off and I get an orange LED.
          I tested the card as a secondary adapter and found that when the drivers load, GPU-Z indicates 0MB on the memory and a 0Mhz core and memory speed.
          I created a Linux boot stick and ran a training check with the Radeon test software and it reports no errors on the memory.
          This same test on another Radeon RX6800 with a known bad memory module does indicate the faulty module.
          What could be wrong with my XFX...
          01-29-2025, 01:33 PM
          AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
          The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
          10-01-2024, 01:07 PM
          AMD Radeon RX 470 / RX 580 Schematic & Board View
          The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
          10-01-2024, 12:52 PM
          AMD Radeon R7 340 / R7 430 Schematic & Board View
          The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
          10-01-2024, 12:36 PM
