A1418 820-3588-A Audio Problem
  • zimeyh
    • Apr 2014
    • 18
    • alibahbay
    hello, I have two boards with the same problem, both 3588. In one the audio worked for me (it recognizes the internal speakers) sometime, but when you restart it it stops working. I tried with other bios, speakers, format so. Has it happened to someone? Any solution? All the best
  • reformatt
    • Feb 2020
    • 1403
    Re: A1418 820-3588-A Audio Problem
    Try a pram reset
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
    • falcontech
      MOTU TRAVELER MK3 AUDIO PROBLEM
      by falcontech
      Good Afternoon
      I have a problem with this MOTU audio card, a traveler MK3, the connection to the computer is via firewire, the card is recognized by the computer (both mac and win) but I have no audio output, on the front there are a series of LEDs including the clock (44.1, 48, etc.) and that LED at the time of connection usually remains fixed telling me the clock frequency set on the computer, now at every start the LED in question remains flashing in most cases, sometimes it becomes fixed, other times it disappears, without any sign of operation, I exclude problems with the firewire chip,...
      01-24-2025, 08:47 AM
    • Gibon378
      Problem with stopping audio and video for no reason
      by Gibon378
      PC Specs:
      • CPU: Ryzen 5 1600
      • GPU: GTX 1080 Palit JetStream
      • MOBO: ASRock ab350 PRO4
      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
      • PSU: XFX 650W (don't remember what model)
      • OS SSD: ADATA SP920
      • OS: Windows 10 21H2
      Problem description:
      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
      11-19-2022, 09:41 AM
    • reset1986
      IMAC A1418 no internal audio
      by reset1986
      hi, i have this imac that does not emit sound from the internal speakers, when i turn it on i hear the boing, but once in the system it has no audio from the internal speakers,
      with headphones you can hear it, in the settings there is always the digital output active, or when i insert the headphones it changes headphones,
      i disconnected the headphone jack plate on the motherboard but it does not solve the situation, do i have to replace it? ic audio?...
      04-04-2025, 09:10 AM
    • tk5ep
      Stanmore JN3018 audio problem help request
      by tk5ep
      I've been given a non working Stanmore JN3018 loudspeaker.
      The power supply part works normally, I have all voltages on all chips. But no sound is coming out.
      I tried to track the audio signal from the inputs to the loudspeaker.
      Unfortunately, it's not easy, as most signals are PWM. But the analog part is working, and I can track the PWM at the inputs of the TAS5508c.
      At the TAS5508c output, I only have pulses which I can find on the input of the final amplifier TAS5342a.
      Can somebody help me to resolve this problem ?
      02-16-2025, 10:46 AM
