AORUS GTX 1080 ti 11gb no signal video
  • Hotpepere
    • Aug 2021
    • 10
    • France
    Hello
    I'm currently bugging the diagnostic of a GTX 1080ti 11gb
    I bought it in good condition for repair
    following a visual inspection under the microscope I noticed a shock at the level of the SLI and several HS tracks which are being repaired
    here is the beast:
    https://imgur.com/1O8d36E
    I think this shock caused some more damage and I will need a little helping hand in the future as I cannot get my hands on the GIGABYTE GV-108 11gb boardview schematics.
    I did a tension check and here is what emerges
    https://imgur.com/yG6HN5U
    I have all the Magic R22 coils and Vcore capacitors short circuit a (upstream and downstream test of the component against ground).
    Then passage of thermographic camera and here is what emerges, the GPU is necessarily cold and a component seems HS at more than 50 degrees celcius seems linked to the breakage on the SLI side
    https://imgur.com/0A3WN5E
    https://imgur.com/rX4uE1E
    and here is the component in question AA7s ->U551
    https://imgur.com/GT9RMub
    and indeed it is short circuit to the mass. But I have a problem.
    I think this component is an A7 switching diode but I have a big doubt about the reference and the characteristics because I am not an electronic technician.
    Could you first confirm or not my readings and what I should have in theory help me identify this component?
    thanks in advance
    :Etats-Unis:
  • dj_ricoh
    • 2073
    • uk
    Re: AORUS GTX 1080 ti 11gb no signal video
    Lift one side of all the coils and write back the resistance on VRAM and Vcore.
    check mosfets and see what type you have.
    You must identify where the gate comes to the mosfet. Usually its UGATE and LGATE.
    If moasfet has 12v then you have a problem where the gate comes from.
    I suspect they are DrMOS. sometimes a DrMOS can short the whole trace to ground. that will be hard but doable.
    • Hotpepere
      • Aug 2021
      • 10
      • France
      thank you for the advice I will measure its, but before I must resolder the cut tracks first and especially identify the HS component to put the good in place because it is dead it is short. then I would do a general check Vcore and Vram to see if a mosfet is dead
      • dj_ricoh
        • 2073
        • uk
        i have no documentation but if you fix the problem before then you can take that out and see what voltage comes there and from, where does it go, to what component and what values it needs to have.
        You know it comes there with 12v and it goes to and ic with 3.3v because the specs on that ic on that pin says MAX 3.3v.
        You try to find what it needs to do from where it comes from and where it needs to go.
        i`m similar stage but i need a soft wire brush in order to identify pins. Pass over the PCB to find with continuity. Anyone knows where to find?
        • Hotpepere
          • Aug 2021
          • 10
          • France
          As for a soft metal brush, the NorthridgeFix youtuber offers electronic equipment that can be found by yourself everywhere and I believe that it has adapted for this use
          otherwise a scalpel in the shape of a thin hook at the end allows the mask to be scratched slightly in order to take measurements
            Thermal pad thickness for various laptop GPU / Graphics Cards
            ASUS Dual RTX 2070 OC 8GB
            ASUS ROG STRIX RTX 3080 OC
            ASUS ROG STRIX RTX 3090
            ASUS TUF Gaming RTX 3080 OC Edition
            ASUS TUF GTX 1660 S-O6G GAMING
            EVGA RTX 3060 Ti XC GAMING 8GB
            EVGA RTX 3060 XC GAMING 12GB GDDR6
            EVGA RTX 3080 FTW3 ULTRA GAMING
            EVGA RTX 3080 TI FTW3 ULTRA GAMING
            EVGA RTX 3090 XC3 ULTRA GAMING 24GB
            Gainward RTX 2080 Phoenix GS Specs
            Gainward RTX 3070 Phoenix 8GB
            Gainward RTX 3080 Ti Phoenix
            GIGABYTE AORUS RTX 3080 MASTER 10G
            02-09-2024, 08:08 AM
            Gigabyte AORUS AORUS 15P XD Notebook Specification for Upgrade or Repair
            This specification for the Gigabyte AORUS AORUS 15P XD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the AORUS 15P XD boardview and AORUS 15P XD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-07-2024, 05:00 AM
            Gigabyte AORUS AORUS 15P Notebook Specification for Upgrade or Repair
            This specification for the Gigabyte AORUS AORUS 15P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the AORUS 15P boardview and AORUS 15P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...
            09-06-2024, 10:50 PM
            Gigabyte AORUS AORUS 17G Notebook Specification for Upgrade or Repair
            This specification for the Gigabyte AORUS AORUS 17G Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the AORUS 17G boardview and AORUS 17G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...
          • AstutePauciloquent
            Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
            by AstutePauciloquent
            Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
            I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
            11-23-2023, 11:02 PM
