Gigabyte RTX 2070 error 43 but no artifacts, crashes on driver load
This topic has been answered.
  • dl123
    • Jun 2021
    • 8
    Re: Gigabyte RTX 2070 error 43 but no artifacts, crashes on driver load
    Originally posted by Joe24
    Yes.... Now what measurements led you to the conclusion that you had faulty DrMOS chips? In what way were they "bad"?
    I accidently shorted one drMos so 2 need to be removed or replaced. I don't have an oscilloscope so couldn't check that. After removing the 2 drMos chips the gpu started working. After time it kept getting code 43 again so I thought the gpu is dead. I then decided to transfer it into a newly built system and it started working again. The system installed old drivers automatically and im guessing that made it work again. The driver version is 457.51.
    • dl123
      • Jun 2021
      • 8
      I did use an oscilloscope to check the output of each DrMOS (when I still had the card), and all phases looked even. Initially, that was my suspicion too, that I had a dead power phase. But everything seemed normal. I don't know how to explain the difference in gate resistance. All I know is, the outputs seemed correct.
      Have you tried installing older drivers?
        Thermal pad thickness for various laptop GPU / Graphics Cards
        ASUS Dual RTX 2070 OC 8GB
        ASUS ROG STRIX RTX 3080 OC
        ASUS ROG STRIX RTX 3090
        ASUS TUF Gaming RTX 3080 OC Edition
        ASUS TUF GTX 1660 S-O6G GAMING
        EVGA RTX 3060 Ti XC GAMING 8GB
        EVGA RTX 3060 XC GAMING 12GB GDDR6
        EVGA RTX 3080 FTW3 ULTRA GAMING
        EVGA RTX 3080 TI FTW3 ULTRA GAMING
        EVGA RTX 3090 XC3 ULTRA GAMING 24GB
        Gainward RTX 2080 Phoenix GS Specs
        Gainward RTX 3070 Phoenix 8GB
        Gainward RTX 3080 Ti Phoenix
        GIGABYTE AORUS RTX 3080 MASTER 10G
        02-09-2024, 08:08 AM
      • LealEletronic
        Gigabyte GeForce RTX 2070 Gaming OC 8GB - Schematic
        by LealEletronic
        Hello guys.
        I'm looking for the schematics for Gigabyte GeForce RTX 2070 Gaming OC 8GB. I already have the boardview, but I need the schematics. I found them on a Russian site but I'm from Brazil so I can't purchase from there.
        If some one can help me, please.
        This schematics is the same as the EVGA 2070, so a really need.
        04-16-2025, 11:42 AM
      • osrex
        LED DRIVER KEEPS DYING
        by osrex
        Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
        i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
        i have no datasheet at all for the LED lights, all i have is its length.
        long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
        as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
        05-05-2025, 03:36 PM
      • Traptor
        Gigabyte GV-N960WF2OC-4GD black screen after driver install
        by Traptor
        Hi Guys,
        I have a Gigabyte GV-N960WF2OC-4GD card.
        I got his card in wrong state.
        Windows start normal mode and I got picture but after driver install I got only black screen. The PC is not freezing because I can reboot using keyboard.
        I tested the card with mats/mods and I did not recognize problem.
        for example the ./mats -e 20 got PASS.
        So, where can I find the problem?
        10-15-2023, 01:43 PM
        NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
        The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
        10-02-2024, 07:51 AM
