Question for all
  • Shodan486
    • Nov 2009
    • 203
    Question for all
    I've read somewhere here that somebody made a modded BIOS version for the ABIT VP6...I just like to ask what are the new options? Is there some sort of extended choice for VCC3.3, like 3.7v? -> This particularly I wanna know.
    Anyways I would like to try it, beacuse I miss the Video BIOS Cachable option in mine
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
  • EbrahimSiami
    Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
    by EbrahimSiami
    I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
    **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
    **What I have tried so far:**
    1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
    07-02-2025, 02:31 PM
  • Foetuss
    Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
    by Foetuss
    Hi all
    Hope this is in the correct place.
    I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
    Could use some double checking to see if I'm not doing something stupid .
    Pictures of the boards are attached.
    What I will be replacing with what : (planned)
    Soltek Golden ::
    4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
    6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
    01-18-2025, 11:44 AM
  • ziplock
    Abit BE6-II motherboard
    by ziplock
    Greetings,
    I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
    I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
    04-20-2025, 02:09 PM
  • прямо
    ASUS TUF B450M-PLUS-PRO overcurrent modded bios
    by прямо
    The ZIP contain the modded BIOS CAP files for PRO and PLUS, latest version 4622. They have been verified to work by user Fernon...
    03-24-2025, 06:59 PM
    ABit IP35 Pro Motherboard Schematic
    ABit IP35 ProABit IP35 Pro Motherboard Schematic
    A motherboard based on the Intel P35 Bearlake-P+ RAID chipset....
    10-31-2024, 02:06 PM
