elitedesk 800 G1 TWR PC ram not working
  • aijazali
    • 123
    • saudi arabia
    hello all how are you
    i have problem hp elitedesk 800 G1 TWR PC ram not working any solution i flashed bios eprom chip and also Changed super IO chip but same problem 5 long beeps 3 time if anybody know that kind of problem plz share with me
  • altaf0001
    • Nov 2021
    • Pakistan
    Re: elitedesk 800 G1 TWR PC ram not working
    I have also same issue. Any suggestion plz
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3610
      • slovakia
      ram is connected right from cpu, so mostly bad balls under CPU
      • kolebbk
        HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
        by kolebbk
        Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
        HP Endpoint Security Controller problem
        there is a problem with the hp endpoint security controller on the unit
        I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
        09-04-2024, 12:44 AM
      • mohamed mm
        Dell inspiron 5520, 7 beeps problem
        by mohamed mm
        I've an Inspiron laptop model 5520, board name, la 8241p, with a 7-beep problem.
        exist voltage:
        PL 200:3.3v
        PL 201:5v
        ram volt PL300: 1.5v
        PL600: 0.9v
        PL500: 1.0V
        PL 202: 19V
        Processor section:
        PL701: 1.2V
        PL702:1.2V
        but PL704: 0.0V
        and PQ705 / PQ706 are zeros on gate/drain and source.
        PC724/PC712 : 19V.
        bios volts:
        EN25QH16 / EN25Q32B: 3.3v.
        I tried to program a (W25Q32B) BIOS chip with an (EN25Q32B) BIOS dump from the internet, but during verification, it says
        08-22-2025, 07:13 AM
      • cygron
        Dell Latitude 3440 2 Beeps Problem
        by cygron
        Model: Dell Latitude 3440
        Board id: DL340-HSW MB 13221-1 Rev: A00
        Laptop produce 2 beeps. RAM is ok (replace and test). And i think RAM Slot is also ok. Board have 2 RAM Slots. All coils have voltage expect PL5101. DRAMRST has only 0.12V. BIOS flashing can't solve the problem. Need help.
        PL4503 - 3.3V
        PL4101 - 5V
        PL4902 - 1.35V
        PL4801 - 1V
        PL4701 - 1.7V
        PL4401 - 17V
        PL5101 - 0V
        PU5102 pins -
        Pin 1 - not stable ( 0.5, 1.3, 5.9 etc ... )
        Pin 2, 4 - 0V
        Pin 3 - 0.95V
        Pin 5 - 2.87V
        Pin 6 -...
        04-20-2025, 03:46 AM
      • jaaa1976
        HP EliteDesk 800 G4 Mini PC -There is a problem with the security device on the unit
        by jaaa1976
        Hi everybody !
        I bought this pc from ebay with error - There is a problem with the security device on the unit
        please fix my bios.
        Model: HP Elitedesk 800 G4 mini PC (65w)
        serial no. 8CC93326J4
        PRODUCT NO. 4KW04ET#ABU
        32- 16mb bios attached
        Thank you so much...
        12-19-2024, 06:48 PM
      • Rkcinfo
        hp elitedesk 800 g3 mini 6 beeps
        by Rkcinfo
        Dear friends. I need your help, this is the first time I've created a topic here on the forum, if it's not correct, please let me know.
        This hp mini pc came from the customer with a logo in the bios and was supposed to be exchanged for the bios with the hp logo, I removed the chip and made the backup for editing but now it doesn't show the video even with the previous bios, It turns on by itself and emits 6 long beeps and 3 short beeps. need help.
        Motherboard mb rev a 16515-1
        S/n brj804mypg
        01-27-2024, 03:51 PM
