iMac A1312 820-2828-A only led one lit
  • bellyacres
    • May 2019
    • 10
    I'm stuck staring at the schematic.
    PP12V_G3H is 12.02
    PP3V42_G3H_REG measured on the output of L7900 is 3.38. The schematic indicates that is should be at 3.425. I'm not sure if that is causing my problem or not. Somewhere I have it in memory that it needs to be 3.425.
    I have 3.39 at the power button also.
    Any pointers most welcome.
    Using the schematic and boardview from this post.
    https://www.badcaps.net/forum/showth...ght=820-2828-a
  • qonma
    Kuli Solder
    • Jun 2017
    • 184
    • INDONESIA
    Re: iMac A1312 820-2828-A only led one lit
    PP12V_G3H is 12.02
    cek the pin, sometimes corotion, or soldering not conected with the board
    • piernov
      • Jan 2016
      • 4436
      • France
      3.38V should be fine. Make sure the power button is working, if possible try another PSU, and go through the list of power rails to see what's present/missing. (G3H→S5→S3→S0)
      • bellyacres
        • May 2019
        • 10
        Power button is testing fine. I've got the PSU and MB out of the machine anyway. The solder looks fine in the connector. I've just been shorting the two pins together, not using the actual power button.
        I don't have another PSU. On the MB, connector J600 the only voltage present is pin 11 at 12.09, and pin 13 at 4.29.
        Q610 has the 4.29 on ping 3, I believe that pin 1 (PM_EN_P12V_SO_FET) should get 12v to turn on the PSU. I have 0v on that pin regardless of the power button state.
        I'm clueless on where exactly to test for S5, S3, S0...
        Unless I've totally missed it the 12.09 is G3H. Yes?
        • guzq
          • May 2017
          • 54
          • Indonesia
          Hey bellyacres,
          Did you solve this issues ?
          I've same issues but Q610 pin 3 = 0v
          I got 1 LED lit, checked all power rails from S5 to S0 all present
          R501 pin 1 = 3.3v / pin 2 = 1.8v
          R502 pin 1 = 3.3v / pin 2 = 3.3v
          R503 pin 1 = 3.3v / pin 2 = 3.3v
          R504 pin 1 = 3.3v / pin 2 = 3.3v
          • mon2
            • Dec 2019
            • 14265
            Hi. This thread should be in the desktop forum.
            Sounds like a bad gpu.
            https://www.ifixit.com/Answers/View/...+LED+1+present
