Gigabyte 7VM400M-RZ
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Gigabyte 7VM400M-RZ
    Pretty miffed when my 7VM400M-RZ stopped working, quite a handy board for testing Socket 462 processors
    First try at resuscitation was replacing its larger capacitors, when that didn't work, all smaller ones as well
    Still dead as, so I embarked upon what would usually be my first try, reprogramming the BIOS externally
    Unfortunately Gigabyte being one of those $hit manufacturers who added a couple of cents to their profit margin by soldering BIOS chips directly to the board, I had to cut the chip out
    solder in a socket
    -then- program a replacement chip
    Still no sign of life
    I'm now considering a north bridge reflow, although have had one success
    https://www.badcaps.net/forum/showthread.php?t=47708
    and one failure with that
    https://www.badcaps.net/forum/showthread.php?t=50171
    Any suggestions?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • 21175
    Re: Gigabyte 7VM400M-RZ
    The schematic might help. Are you getting any voltage on the bios and power switch.
    • piernov
      • Jan 2016
      • 4437
      • France
      "no sign of life" is quite vague. No point in suspecting BIOS or MCH if there is no power at all and it doesn't even try to turn on when triggering power button.
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        Poor choice of words - board always powers on, so no sign of POST would be more accurate
        BTW here's pics meant to be in original, which I cannot now edit
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          via board huh? since u had one success reflowing a via board, i say go for it again!
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Hmmm. I see green Sanyo caps on those pics. Are they WG or WF series? If WF, you might want to replace them. They are known dud series, though they usually bulge the same way as United Chemicon KZG - i.e. typically when they are not used for a long time.
            Other things to suggest:
            - Did you try the board with a different stick of known good RAM? What happens if no RAM is installed? Motherboard beeping errors or not?
            - Did you try re-installing the CPU. Old CPUs and sockets are usually very resilient against corrosion, but it doesn't hurt to try and reinstall the CPU a few times to clear any possible surface dirt on the contacts in the CPU socket.
            - Was the CPU and RAM inserted and removed many times before? CPU and RAM sockets aren't meant for frequent component swapping, so if you did this every time you used the board, that could be a problem too. (Though it should be noted that CPU and RAM sockets can still probably take around 100 insertion cycles safely, so I doubt this is the issue here. Still had to mentioned it anyways, not knowing the history of the motherboard or how it was used.)
            - Have a PCI POST card or can borrow one? Older boards are usually pretty decent about displaying POST codes on POST cards. The code is actually not that important, but rather seeing if the board is even trying to POST. This is handy for narrowing down the issue to voltage and/or enable signal problem or a component getting stuck at POST.
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              Green caps are recent Suncon, albeit from eBay, checked on Transistor Tester before use - replaced KZGs which looked fine before removal
              Tried with several different RAM, varying from DDR266 to DDR400, seeing test CPU is a Duron 800
              No beeps if no RAM
              Duron recently removed to test on another board (ironically a PC Chips M810) to verify it was working
              CPU hasn't been changed too often - something I try to avoid, especially with sockets having flimsy HSF clips
              POST card's LED card showed No Signal as I recall - reason I wanted to try another BIOS chip
              It's winter here in Southern Hemisphere - I'll probably try ChaosLegionnaire's suggestion when my garage becomes habitable again
              • DynaxSC
                GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                by DynaxSC
                I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                General test conditions:
                - Tested with Core i5 6500 and Core I7 6700K - no difference
                - Default BIOS settings, but tried also altering several memory setting - does not change anything
                What is wrong:
                With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                03-21-2025, 06:23 PM
                Thermal pad thickness for various laptop GPU / Graphics Cards
                ASUS Dual RTX 2070 OC 8GB
                ASUS ROG STRIX RTX 3080 OC
                ASUS ROG STRIX RTX 3090
                ASUS TUF Gaming RTX 3080 OC Edition
                ASUS TUF GTX 1660 S-O6G GAMING
                EVGA RTX 3060 Ti XC GAMING 8GB
                EVGA RTX 3060 XC GAMING 12GB GDDR6
                EVGA RTX 3080 FTW3 ULTRA GAMING
                EVGA RTX 3080 TI FTW3 ULTRA GAMING
                EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                Gainward RTX 2080 Phoenix GS Specs
                Gainward RTX 3070 Phoenix 8GB
                Gainward RTX 3080 Ti Phoenix
                GIGABYTE AORUS RTX 3080 MASTER 10G
                02-09-2024, 08:08 AM
                A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                by momaka
                More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                And a shot of the label:...
                01-26-2022, 03:26 AM
              • nikovmiroslav
                Gigabyte A5 X1 Need Bios
                by nikovmiroslav
                Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                Gigabyte A5 X1
                From motherboard:
                S/N: 1TNH55ER1350895
                P/N: 6-77-NH55ERQY-D02-2CGB
                On sticker from the back of the laptop:
                S/N: SN21351J000657...
                08-24-2025, 09:15 AM
                Gigabyte Notebook Specification for Upgrade or Repair
                This specification for the Gigabyte Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the boardview and schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte Notebook is accurate, safe,...
                09-07-2024, 07:19 AM
