Asus M2n4-sli
  • c_hegge
    • Sep 2009
    • 5219
    Asus M2n4-sli
    I recently aquired this motherboard from work. According to the customer, it would post sometimes but not others times (although I couldn't get it to post at all at work). Caps are as follows
    4x 1000uF 16v Chemi-Con KZG
    9x 1500uF 6.3v KZG
    1x 470uF 16V KZG
    2x 1800uF 6.3v Panny FJ
    25x 6.3v 820uF FJ
    Obviously, the KZG need replacing. I have Panny FJ for the 1500uF 6.3v, FL for the 1000uF 16v and Sanyo WG for the 470uF 16V.
    Let me know if any of the replacements aren't suitable.
  • c_hegge
    • Sep 2009
    • 5219
    Re: Asus M2n4-sli
    Done the re-cap. and it seems to POST reliably now, although it takes ~30 seconds for the first power-up since the 5vsb was removed. I'm currently installing windows on it. I'll let you know how it goes with the Prime95 stress test.
    • c_hegge
      • Sep 2009
      • 5219
      Re: Asus M2n4-sli
      Looks like it is fixed. it ran for more than 48hrs in prime95.
      • POM_MJ
        • Aug 2009
        • 228
        Re: Asus M2n4-sli
        I've got an identical M2N4-SLI board from my friend.
        it can not POST (BIOS beep not find any display adapter, beepppppp....beep.beep.)
        most of caps on my board are Chemicon KZG.
        All of them has no sign of bloat or any damaged.
        Could it possibly back to live, if I recaps all KZG to Panasonic.FJ?
        Pics will post later
        | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
        | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
        | 2xWD7500AYYS | 2xHD322GJ Raid0 |
        • c_hegge
          • Sep 2009
          • 5219
          Re: Asus M2n4-sli
          Yes. KZG can die without bloating
          • POM_MJ
            • Aug 2009
            • 228
            Re: Asus M2n4-sli
            This one is mine, full of KZG. too many 820/6.3V caps
            Where should I start to recaps for symptom cannot detected display adaptor?
            • c_hegge
              • Sep 2009
              • 5219
              Re: Asus M2n4-sli
              Start with CPU VRM (All the caps on my second pic at the start of the thread). If that doesn't help, then replace the others.
              • POM_MJ
                • Aug 2009
                • 228
                Re: Asus M2n4-sli
                OK, I will start from there, thanks.
                • mockingbird
                  • Dec 2008
                  • 5484
                  Re: Asus M2n4-sli
                  The new Asus boards use all polymers for the VRM and KZG for the rest of the motherboard.
                  Funny, last week I had problems with a P5KPL-CM that had all pannies. It would crash in 3Dmark2001 and would POST only intermittently. And the interesting thing was, the board was all Pannies. Either they were fake, or the board had some kind of design flaw.
                    • 31255
                    Re: Asus M2n4-sli
                    or they died from a log overheated life.
                    they are only rated for 2000 hours at 105' remember.
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3113
                      Re: Asus M2n4-sli
                      But thats also at the maximum ripple current and voltage among other things.
                      I think rubycon the company says that for (their caps at least) for every 10C drop in temp the cap life doubles.
                      • POM_MJ
                        • Aug 2009
                        • 228
                        Re: Asus M2n4-sli
                        I've done recaps around CPU socket.
                        4x1000/16V.Chemicon.KZG -> 4x1500/16V.Panasonic.FL (ATX12V ?)
                        6x1500/6.3V.Chemicon.KZG -> 6x1800/6.3V.Panasonic.FL (Vcore ?)
                        3x1500/6.3V.Chemicon.KZG -> 3x1800/6.3V.Panasonic.FL (near IDE connectors)
                        1x470/16V.Chemicon.KZG -> 2x470/16V.Samxon.GK (near PCIe slots.)
                        I have no AM2 processor now , I will get one tomorrow.
                        Any suggestions welcome?
                        • POM_MJ
                          • Aug 2009
                          • 228
                          Re: Asus M2n4-sli
                          Yeh!, Its work!.
                          I will test it's stability next time after find a better chipset heatsink.
                          Thankyou Badcaps.net
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Re: Asus M2n4-sli
                            Remember, the other KZG caps could fail in the future, so look at obtaining some replacements for them too.
                              • 31255
                              Re: Asus M2n4-sli
                              you shouldnt test pcb's on antistatic foam - the pink or gray stuff!
                              • POM_MJ
                                • Aug 2009
                                • 228
                                Re: Asus M2n4-sli
                                Yes, its not stable! while KSG. are still there.
                                I've recaps some of KZG.820/6.3V to FJS.820/6.3V around DRAM area and PCIe slots, run better stable.
                                I decide to replace all of KZG.820/6.3V, but... too many.
                                please explain, why?
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  Re: Asus M2n4-sli
                                  It's supposedly conductive, although I have done it before and not had problems.
                                    • 31255
                                    Re: Asus M2n4-sli
                                    i saw a guy power one up sitting on one of the silvered bag's once and it arced & blew the board!
                                      • 31255
                                      Re: Asus M2n4-sli
                                      btw, stop changing the chipset heatsink!
                                      get a really tall sink that dont need a fan - it's more reliable.
                                      the tiny fans die, they have been the cause of several dead motherboards here.
                                      • POM_MJ
                                        • Aug 2009
                                        • 228
                                        Re: Asus M2n4-sli
                                        wow, I will more careful with these.
                                        my friend cannot find the original heatsink.
                                        the gold tall sink in the pics that's CM blue ice, I've moved its fan to NF4-D.
                                        I will find a big tall one with fan included for safe.
                                        thanks for suggestions.
