XFX Radeon 7770 Possible Short
  • leotron
    • Apr 2019
    • 29
    • Offworld
    Hello there this is my 2nd post in this great community, always reading and learning something new.
    I'm going straight to the point, I have this graphics card XFX Radeon HD 1ghz Edition which I was using with a faulty PSU (CoolerMaster 450w), I said faulty because the PSU was old and showing some symptoms, like the power wasn't enough for this card, so to in order to use it I decided to underclock it and it keep functioning. One day suddenly the PC reboot and the card is not displaying any signal or it's detected by Windows or Linux. When I plug this card in the PC the fan spin at full speed for a few secs and then it lower the speed at normal, I read in another website that this is a signal that it's shorted.
    Going back to the card I'm going to describe what I found, primarly the 4 mosfets in the right side of the first image, I retired them I check with a multimeter and they are OK (not shorted), the PCB is the problem since the place where is soldered it's shorted. And a few other caps near that are shorted too but this maybe be something normal since some of them acts like a filter.
    I suspect of the PWM , it's a APW7098 and I need some knowledge of yours to give me a clue where to start.
    Also I found this other thread which discussed a similar problem, found it very helpful https://www.badcaps.net/forum/showthread.php?t=35004
    In the attached images I marked with green the components that aren't shorted, and with red those who are. Some of them I desoldered to check if they were faulty.
    Best regards.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: XFX Radeon 7770 Possible Short
    What is the exact resistance to ground measurement on GPU VCore?
    • leotron
      • Apr 2019
      • 29
      • Offworld
      I'm sorry but I double check the resistances in the mosfets pins around the crossfire section and it give me another resistance. I'm gonna attach the corrections. Also I check resistance from GND to the 3 coils nears the mosfet and GND to the 12v pins molex.
      Thanks for answering, I'm sorry to ask you this but how do I find the VCore pin? I found an image of another GPU on the internet.
      https://i.imgur.com/FpXZPxT.jpg
      Thanks for your time, I'm gonna give an opportunity to this card before I sold for scrap.
      • piernov
        • Jan 2016
        • 4439
        • France
        GPU VCore is the section you were working on.
        Resistance can be measured between inductors pins and ground (large black squares, I don't see marking on those 2 unlike the other ones) or across the capacitors leads (the silver/blue capacitors) that you previously removed.
        EDIT: sorry answered without looking at the picture. There doesn't seem to be any short to ground on this board. What is the voltage on GPU VCore when it's running?
          AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
          The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
          10-01-2024, 12:46 PM
          AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
          The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
          10-01-2024, 01:07 PM
          AMD Radeon RX 470 / RX 580 Schematic & Board View
          The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
          10-01-2024, 12:52 PM
        • Byte_76
          Faulty XFX Radeon RX6800 Merc 319. (Non-XT)
          by Byte_76
          I have an XFX Radeon RX6800 which allows me to boot into Windows but as soon as the drivers load, the screen turns off and I get an orange LED.
          I tested the card as a secondary adapter and found that when the drivers load, GPU-Z indicates 0MB on the memory and a 0Mhz core and memory speed.
          I created a Linux boot stick and ran a training check with the Radeon test software and it reports no errors on the memory.
          This same test on another Radeon RX6800 with a known bad memory module does indicate the faulty module.
          What could be wrong with my XFX...
          01-29-2025, 01:33 PM
          AMD Radeon R7 340 / R7 430 Schematic & Board View
          The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
          10-01-2024, 12:36 PM
