ga-h61m-s2pv restart .
  • mo000
    • Nov 2017
    • 276
    • algeria
    motherboard restart after second's without data on screen .
    debug card shows code 15 sometimes 53
    i flash the bios
    change ram+cpu+power
    but the problem still exist .
  • brethin
    • Dec 2008
    • 1907
    Re: ga-h61m-s2pv restart .
    get new board.
    • piernov
      • Jan 2016
      • 4435
      • France
      15 doesn't ring any bell but I think 53 is usually related to RAM.
      Try with other compatible RAM sticks.
      Check and clean RAM slots.
      Check for any broken pin in the CPU socket.
      Make sure CPU is compatible with the board.
      Check RAM supply voltage.
      • mo000
        • Nov 2017
        • 276
        • algeria
        thank you
        voltage on pin 236 in ram socket = 2v should be 3.3 because vcc3
        • platinumsteel
          • May 2019
          • 234
          • Trinidad&Tobago
          Originally posted by mo000
          thank you
          Hi did u get tru and figure out the exact issue for your Gigabyte Board?
          • shouri
            Dell latitude e5490 auto restart
            by shouri
            Hi guys, can someone help me?
            I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
            Board model is dm70 la-f401p rev:1.0 2017-09-20.
            At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
            After a few days test, is seems ok.
            Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
            12-10-2024, 09:27 PM
          • Rauni
            Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
            by Rauni
            Hello, this is my first post on this forum, and my first attempted to repair a TV.
            My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
            Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
            Read also that we should test what happens if we...
            10-01-2023, 12:06 AM
          • DynaxSC
            MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
            by DynaxSC
            Hi Folks
            I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
            Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
            09-29-2024, 04:27 PM
          • DynaxSC
            Weired MSI B560M PRO (MS-7D20) - not starting with 11-th gen. CPU, 10-th gen. OK
            by DynaxSC
            I have a very weired problem with MSI B560M PRO (MS-7D20), board is upgraded to the latest BIOS version v1.9.
            The board is normally starting with 10-th gen. CPU, ie. Intel Comet Lake i5-10600K and Celeron G5905.
            However if I install a 11-th gen. Rocket Lake i5-11600K the board powers up, but is immediately stuck on CPU LED, not progressing further. Debug card shows FF, and after restart with long short of Power Button: FE, which is as usually of no help (Reserved for future AMI error codes).
            According to MSI compatibility site the board supports...
            11-04-2024, 04:04 PM
          • cekcons
            M2 Sata SSD failed - important data exist
            by cekcons
            hi everyone ! I do have a faulty ssd its m2 (sata i do belive). When i plug in to board and boot my pc it stucks on bios forever. I unplug it and it boots fine. I tried usb adapters etc still no dice.
            But I found out that i can enable "ROM" mode (?) by shorting two debug pings at back of ssd. Now i can boot and it shows up as a 1gb drive on my device with "not started" mode. Name that it showed up is : SM59XT2A-80-10000001
            ​My ssd brand is "TWINMOS" which is i do belive just a china rebrand. it is a 256 gb drive. only two storage chip on the thing. I...
            06-22-2024, 06:21 AM
