GA G31M-S2L NO DISPLAY restart loop .
  • mo000
    • Nov 2017
    • 284
    • algeria
    the motherboard in post card count to code c1 (ram code) and restart
    the ram voltage and vtt are correct 1.8v and 0.9v
    and ram bios volt is 3.4v
    i flash bios
    flash bios in new bios chip
    the same thing always power on and restart .
  • ezzeddin
    • Feb 2019
    • 16
    • syria
    Re: GA G31M-S2L NO DISPLAY restart loop .
    your problem almost southbridge
      master hoarder
      • May 2008
      • 12175
      I imagine you tried different (and known good) RAM modules? Also, just try only one RAM module at a time in either slot. It's possible the RAM slot contacts could be a bit oxidized and thus not making good contact. -OR- since this is LGA775 motherboard, there is also a small chance the BGA under the CPU socket could have been damaged/cracked from a push-pin cooler (those stock Intel heatsinks are known to warp the board quite a bit.) That said, before even thinking about any socket reflows, consider inspecting the CPU socket pins first. Memory errors can also be caused if there is a bad pin (or two... or more) in the CPU socket.
        by Vesko356
        08-11-2023, 03:27 AM
      • lanovey
        SF314-41 BIOS without internal display
        by lanovey
        Hello there,
        I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
        I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
        06-13-2025, 02:38 AM
      • abhorsen
        Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
        by abhorsen
        Hey guys,
        Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
        Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
        Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
        07-06-2023, 10:22 AM
      • mrrubik
        Dell Optiplex 7010 micro bad BIOS flash?
        by mrrubik
        Hi folks,
        I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
        After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
        Steps I took:
        1. Read BIOS with CH341a, verified hash twice
        2. Patched
        12-23-2024, 04:11 PM
      • AkaBukai
        Is it okay to flash stock bios onto the motherboard's BIOS?
        by AkaBukai
        Hi there,
        I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
        The little LED on the power button is flashing slowly and nothing happen.
        This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
        So I decided to flash the BIOS using a cheap programmer.
        And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
        I also...
        12-19-2024, 12:15 PM
