digitalstream dtx9950/15-150 bad "jl" caps.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    this unit less than a year old. it started puzzling even on strong signals and had noise in the rf out since new.
    a neighbor bought it with taxpayers money via one of those $40 cards.
    i expect there will be a ton of these dieing off soon.
    too bad there was no minimum durability standard required for coupon eligible units!
    this plastic heap of shit brought to you by radioshack!
  • japlytic
    • Oct 2005
    • 2086
    Re: digitalstream dtx9950/15-150 bad "jl" caps.
    I guess you are right about the durability standard for coupon eligible units, especially in the electrolytics department.
    • Krankshaft
      • Jan 2007
      • 2328
      I bought the all digital version (no analog pass through) last year around May and it had Daewoo caps on the PSU.
      I replaced them all with Panasonics.
      I couldn't resist opening the unit even though it was working good thing I did.
      A very simple switcher utilizing a garden variety TOP IC.
      Out of all the converter OSDs I liked this one the most.
      I bought it for the hell of it with a coupon just to see what these boxes were all about.
      I'm sure the new boxes still have that annoying ssssssing in one of the channels when receiving Dolby audio right?
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
