I have here acer aspire desktop pc, the problem is when plugged in automatically turn on but no display, I tried replacing with good ram but still the same issue. I notice when i removed the memory and plugged in automatically turn on beeps, so i think board is working, but when i plugged in the memory on the two ram slots no beeps and no display.anyone can help me on this please, i Have attached the img of the board
Acer aspire TC-730 Desktop PC no display
Re: Acer aspire Desktop PC no display
Does it get GFX core voltage? can check the coils around the CPU "region" 1V usually CPU (check the specs for that cpu) 1.2V-1.8V for GFX usually depends... what cpu is that? and what ram is that standard or low voltage? should be getting 1.3V - 1.5V usually depending on type...Last edited by MJ-meo-dmt; 01-10-2019, 05:00 AM.while alive { live(toFullest=true) }
the big coil and the other small coil near the cpu region both 1side have 1.03v and both other side no voltage.both r47 coild near ram slot have both 1.03v both sides.The cpu is onboard on the chip it is INTEL PENTIUM J4205. the bios both pin 8 and pin 3 have 1.8v
Romy would you mind updating your attached image having added all the voltages onto the points you tested. so we can see it on the image.. that would lessen the confusion. thanks.
when you say both one side voltage and both other side no voltage? while the MB is powered? you should have voltage on both sides unless im not understanding u...while alive { live(toFullest=true) }
Hi Romy thanks for the back image :P but i think i didnt make any sense.. attached is a example... the values is just there so I can explain what I meant.
Would you mind doing something like that... or anyway you think would make sense for us so we can have a clear view of what is going on.Last edited by MJ-meo-dmt; 01-10-2019, 06:00 AM.while alive { live(toFullest=true) }
