ASUS A7M266 Kills T-Bred B??
Re: ASUS A7M266 Kills T-Bred B??
Because the Voltage is encoded on the CPU Package.
The old Athlon CPUs had On Chip Jumpers that were laser cut. You might remember the "Pencil trick" for Overclocking, don't you?
So you have to override that.
And as I already stated, you can disable the Jumper Free thingy and set the Voltage manually.
Or in other words:
Someone had to have another CPU in it and overridden the CPU VCore and the Board did not reset that when Changing the CPU...
But even then, what are we talking about?! 2V or more???
No, its toast because I replaced the Caps and the CPU VRM didn't seem to like it somehow...Last edited by Stefan Payne; 06-12-2018, 05:27 PM.Comment
Do you have more information about that?
No, it was already on the Board.
That sounds like Bullshit to me.
Or in other words:
What are you smoking to come up with such shit?!
No, its toast because I replaced the Caps and the CPU VRM didn't seem to like it somehow...Comment
Or in other words:
See, this is why i do not try to help on here much anymore. Arrogant people ask for help then jump on the person trying to help them, thinking that they are a know-it-all. Fix it yourself.Last edited by Sparkey55; 06-13-2018, 08:20 AM.Comment
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
My Compaq Desk Pro EN SFF didn't support coppermine, yet I've used that one with Coppermine for YEARS.
That it isn't officially supported doesn't mean it doesn't work on those older Boards.
Often it does, though with only 133MHz FSB.
Its as I stated earlier...
Single Socket A7M266, not the Dual CPU one...
Because isn't supported does not mean that it doesn't work. It can just mean that the Board was EOL when the CPU was released and the manufacturer of the board didn't bother with it anymore.
I've given you an example with the Compaq Deskpro EN SFF but there are also other cases, where an unsupported CPU does work although it is not officially listed. Sometimes with some caviat like lower FSB and shit like that.
And even if it does not work, it shouldn't destroy anything.
So there has to be something wrong with the CPU VRM of this board...Last edited by Stefan Payne; 06-13-2018, 09:51 AM.Comment
To be precise for the Ceramic Package.
For the Organic packages you need a bit more effort to unlock it, but its still possible...
Anyway, the CPU VCore is encoded on the Package with the on package Jumper Links that are Laser Cutted as needed.
like this
With the Organic package Athlon (XP), you have to insulate the hole the Laser makes because. And then reconnect the connections.Last edited by Stefan Payne; 06-13-2018, 09:54 AM.Comment
Wait, IIRC, on post-T-bird, it's tricky! I thought I saw a folk post that you have to fill a void with non-conductive stuff, then put a conductive adhesive on top of that!ASRock B550 PG Velocita
Arc A770 16 GB
Oh and another Thing that works but isn't supported:
Registred ECC RAM on AMD K8 based systems!
Especially with E-Step K8, you can put in the buffered RAM, if you happen to have an ASUS Board, and it works.
Possibly Gigabyte, but not all Boards (used it on an old PGA754 K8N and K8VT800)
I also tested it with an AM2 K8 and it also works. Sadly they deactivated Registred Support from Phenom upwards (tested it with a 955BE myself, same Board, same RAM as the AM2 CPU)...
Yes, you have to fill the hole burned by the Laser with non conductive glue and then connect the two pins with something conductive.Comment
I've personally never had and never seen a CPU burn out (or burn out the VRM) due to the board not supporting it. That is, as long as the CPU is socket and pin signal -compatible with the board, nothing should burn.
Most VRM controllers have only so many valid V_core voltage states, so at worst, the CPU will select an either an invalid (VRM controller shuts down) or an incompatible voltage (but nothing damaging to the CPU, as VRM controllers are regularly capped at a certain max voltage.) From my experiments, this has always just resulted in no POST, but nothing else. Perhaps for very very old boards (Pentium II or earlier??), this might not be true. But anything Athlon/Athlon XP and Pentium 4 is relatively new in terms of VRM design, and thus fairly protected.
As my most recent example, I put a s775 Pentium 4 CPU into a Intel mobo that only takes C2D/C2Q/PDC CPUs. Did this to test the VRM after a repair (it kept blowing FETs with known compatible CPUs, so I didn't want to risk burning my C2D chips anymore). The V_core with the Pentium 4 CPU was incorrect (1.1V instead of 1.4V), and as expected, the board did not post. But I left it running for a good 20 minutes to see if the VRM would blow a FET again. It didn't. Then I stuck a C2D chip and tested the board again. All was well afterwards. FETs kept blowing because one of the phase drivers was bad, which I changed before testing this last time before trying the P4 CPU.Last edited by momaka; 06-17-2018, 02:02 PM.Comment
This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:00 AM
- Loading...
