Palit Geforce 4 4200 Suddenly Dead
  • shadow
    • Feb 2007
    • 732
    I got a Palit Geforce 4 4200 that has suddenly died.
    It was working one day in the morning and when the PC was turned on in the evening, there was no signal on the monitor.
    It is confirmed that the graphics card is at fault. I had to put in another one as a temporary replacement.
    I was wondering what could have gone wrong with it for it to fail suddenly?
    I looked over the whole board thoroughly and I can not find any burnt out components.
    However there are three bulging caps on it. The card is populated with Canicon 1000uF 6.3V caps.
    Could the fix simply be replacing the capacitors?
  • gdement
    • Jan 2007
    • 690
    Re: Palit Geforce 4 4200 Suddenly Dead
    Clearly the caps are involved. Replacing them might fix it, might not. Depends if they caused any collateral damage.
    • shadow
      • Feb 2007
      • 732
      That's what I thought. I guess what I am asking is whether others have had a similar situation happen to them and what was the problem.
      • linuxguru
        • Apr 2005
        • 1564
        As gdement said, replacing the caps might fix the problem some of the time. It would almost certainly have worked if the caps had been replaced the moment the card started showing symptoms - including garbage on the screen, flaky sync, etc. I would be surprised if it worked perfectly right up to the moment it died.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          had the same problem with a GF4 Ti 4200 (made by PNY)
          no video from one day to another..
          had a few bulging GSC caps (known crap).
          replaced all of them and it works fine
          • shadow
            • Feb 2007
            • 732
            Cool. I will have to source the capacitors.
            The local RS Components outlet has Panasonic FC in stock.
            I will probably get those.
            Only issue is that I don't really have too much time to drive there and get the capacitors. I guess I will have to make time on Wednesday I guess.
            • shadow
              • Feb 2007
              • 732
              Well I got the Panasonic FC capacitors now.
              The local RS Components Trade Outlet has moved location and it is now a lot closer to where I live!
              Hopefully all goes well.
              • shadow
                • Feb 2007
                • 732
                Just an update. The recap has failed. The graphics card is still dead.
                Unfortunately the card fell a distance of about one meter during the recap.
                I think that just cemented its death.
                On the plus side, my test system (a late model P3 system) recognises the video card (there are no missing video card beeps from the motherboard). However no signal is detected.
                I have got a before picture but not an after picture yet.
                  Thermal pad thickness for various laptop GPU / Graphics Cards
                  ASUS Dual RTX 2070 OC 8GB
                  ASUS ROG STRIX RTX 3080 OC
                  ASUS ROG STRIX RTX 3090
                  ASUS TUF Gaming RTX 3080 OC Edition
                  ASUS TUF GTX 1660 S-O6G GAMING
                  EVGA RTX 3060 Ti XC GAMING 8GB
                  EVGA RTX 3060 XC GAMING 12GB GDDR6
                  EVGA RTX 3080 FTW3 ULTRA GAMING
                  EVGA RTX 3080 TI FTW3 ULTRA GAMING
                  EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                  Gainward RTX 2080 Phoenix GS Specs
                  Gainward RTX 3070 Phoenix 8GB
                  Gainward RTX 3080 Ti Phoenix
                  GIGABYTE AORUS RTX 3080 MASTER 10G
                  02-09-2024, 08:08 AM
                  NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                  The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                  10-02-2024, 08:52 AM
                  NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                  The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                  10-02-2024, 07:51 AM
                  NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                  The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                  10-01-2024, 01:54 PM
                  NVIDIA GeForce RTX 4080 (RTX4080) Schematic & Board View
                  The GeForce RTX 4080 is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2022. Built on the 5 nm process, and based on the AD103 graphics processor, in its AD103-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 4080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The AD103 graphics processor is a large chip with a die area of 379 mm²...
                  10-02-2024, 08:57 AM
