I have a gigabyte 81945m-g-rh which has blown 3 capacitor around cpu line and turns on but no display. I try to change this caps but i don't have the same exact value available. the capacitor have 1500uf 16v and i have only 2200uf 16v is it possible to replace with this 2200uf?please need help
Tags: None
Re: gigabyte 81945m-g-rh
Yes it is, but the important spec is ESR and Ripple current.
You need to look at the datasheets to verify that."The one who says it cannot be done should never interrupt the one who is doing it." -
thanks for the response the orginal caps are nichicon and my replacement is jackon capsComment
Manfacturer is irrelevant.
Capacitance is not that relevant
What counts is the rest of the spec:
ESR and Ripple Current.
You can't replace an 820uF Nippon Chemicon KZG with a 820uF KMQ just because they have the same uF!!
In this case you have to either use a Panasonic FM 820uF or you can probably go for a Polymer.
So we need more information.
You have to look up the information.
You can't just replace a cap with the same Votlage and Capacitance!Comment
.... but you really shouldn't just do that.
Ideally, you indeed should look up the ESR and ripple current specs. But if you have caps that are completely bad (visibly blown/leaking), then replacing them with GP crap caps may still be a bit better than trying to run the equipment with the bad caps. But using GP caps in place of low ESR and/or ultra-low ESR caps (especially on motherboard) may eventually make your new caps fail quickly again. It all really depends where the caps are used, though. If it's not around the CPU, you may have better luck with the caps lasting a bit longer. But don't count on it. Get proper replacement caps the first time if you can and do the repair once, but correctly.Comment
Are the original capacitors 1500uF 16V Nichicon HM by any chance? This is a 2006 or 2007 vintage board AFAIK, so I would be surprised to hear that the HM failed unless a very shoddy PSU was powering the board in question or unless the VRM runs very hot.Comment
You can.... but you really shouldn't just do that.
Ideally, you indeed should look up the ESR and ripple current specs. But if you have caps that are completely bad (visibly blown/leaking), then replacing them with GP crap caps may still be a bit better than trying to run the equipment with the bad caps. But using GP caps in place of low ESR and/or ultra-low ESR caps (especially on motherboard) may eventually make your new caps fail quickly again. It all really depends where the caps are used, though. If it's not around the CPU, you may have better luck with the caps lasting a bit longer. But don't count on it. Get proper replacement caps the first time if you can and do the repair once, but correctly.Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
It depends.
If it's just a regular filter for the 3.3V, 5V, or 12V rail (but not an input to a buck-type regulator), or a filter for a linear regulator, then probably yes.
But if you have a buck-type regulator (one with inductor), GP caps are *not* a good idea.
Of course, anything is better than failed caps. And personally, I would rather take good quality Japanese GP caps over Chinese/Taiwanese low ESR caps. Actually, you could technically use GP caps in a buck regulator without any adverse affects if you also add a lot of MLCCs (high-capacity ceramic caps with 4.7 uF or more) in parallel to the GP caps. ATI used to do this a lot on their Radeon HD2000, HD3000, and HD4000 series of video cards - at least for the high-side of the VRM. For the low-side, it was always polymers and/or low ESR conventional electrolytics.
Originally posted by momakaMaybe those were Chemicon KZG? I know Gigabyte usually sticks with Nichicon, so indeed you're correct to assume the caps were Nichicon HM. However, I think I remember seeing a few boards with Chemicon KZG. If not that, perhaps Sanyo WF? I know Gigabyte occasionally used green Sanyo caps, though I never looked to see if they are the WF series or not. WF are indeed dodgy as you've warned me before - I just opened my Gateway GT5656 PC a few weeks ago, and one of them bas bulging just from sitting in storage. Capacity measured over 3x normal. Need I say more?
They would be either WG, KZG, HM, MBZ, or FJ on the OP's board (WF is equal to HN, and WG equal to HM) - I wonder if they were KZG too, because I've seen people mislabel KZG as “Nichicon KZG” before.Comment
Again, not always.
Looks like you guys need to follow my motherboard recap threads more often(that is, whenever I get to posting one). Here's a board filled with 6.3V/1000 uF caps, and you can see they filter all sorts of stuff:
https://www.badcaps.net/forum/showthread.php?t=63164
FYI, this is not the only motherboard like that. I have seen motherboard from ASUS, Gigabyte, ECS, and Jetway all do this - i.e. use one standard value of capacitors (typically 6.3V/1000 uF or 6.3V/820 uF) for just about every major component rail (the CPU V_core typically being an exception, as always).Comment
Yeah, because its cheaper to use one component that is overkill for some parts instead of using another place on the machine to use another component.
And you are right, I was too unprecise.
Let me rephrase it:
The decoupling caps, the ones between the PCI slots (if no Voltage regulator is near them) and the decoupling ones for USB can be swapped with GP ones.Comment
by DynaxSCHi,
I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
General test conditions:
- Tested with Core i5 6500 and Core I7 6700K - no difference
- Default BIOS settings, but tried also altering several memory setting - does not change anything
What is wrong:
With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2... -
Thermal pad thickness for various laptop GPU / Graphics Cards
ASUS Dual RTX 2070 OC 8GB
ASUS ROG STRIX RTX 3080 OC
ASUS ROG STRIX RTX 3090
ASUS TUF Gaming RTX 3080 OC Edition
ASUS TUF GTX 1660 S-O6G GAMING
EVGA RTX 3060 Ti XC GAMING 8GB
EVGA RTX 3060 XC GAMING 12GB GDDR6
EVGA RTX 3080 FTW3 ULTRA GAMING
EVGA RTX 3080 TI FTW3 ULTRA GAMING
EVGA RTX 3090 XC3 ULTRA GAMING 24GB
Gainward RTX 2080 Phoenix GS Specs
Gainward RTX 3070 Phoenix 8GB
Gainward RTX 3080 Ti Phoenix
GIGABYTE AORUS RTX 3080 MASTER 10G
Channel: Schematics and Boardviews
Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
Gigabyte A5 X1
From motherboard:
S/N: 1TNH55ER1350895
P/N: 6-77-NH55ERQY-D02-2CGB
On sticker from the back of the laptop:
S/N: SN21351J000657...-
Channel: BIOS Requests ONLY!
by RotsingerSo the 16v 1500uF capacitor C9B1 near the power connector on the back of a Phat started leaking. Haven't been able to find the right cap, so I replaced it with a larger 25v 2200uF capacitor a couple weeks ago and everything is working fine since then. I didn't replace the other six 16v caps, they were all good.
When putting the fan plastic cover back I remember there were maybe 2-3 mm of clearance on top of it and 1-2 mm of clearance to the side of it.
For those that don't remember what the fan cover looks like I found this picture https://cdn.quade.co/wp-content/uploads/2... -
This specification for the Gigabyte G series G5 KF-5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G5 KF-5 boardview and G5 KF-5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...09-07-2024, 07:19 AM
- Loading...
