Asrock 79 Extreme6
  • m4a2t0t
    • Mar 2013
    • 276
    Asrock 79 Extreme6
    Small cap fell off the board when my hand brushed against it.
    Whats the value of the cap?
    LF
    560
    j
    29A
    Is there a standard coding for aluminum caps or is it up to the manufacturer?
    Thanks!
  • mariushm
    • May 2011
    • 3799
    Re: Asrock 79 Extreme6
    Customs versions of Nichicon PLF, in theory with higher lifetime :
    See bottom right corner of first page in the datasheet.
    Voltage
    e=2.5v
    g=4v
    j=6.3v
    A=10v
    C=16v
    D=20v
    E=25v
    Panasonic and some other brands use the same notation (or a very similar one)
    So you have a 560uF 6.3v rated polymer capacitor. 29A is lot number, nothing helpful to you.
    PS. pay attention to polarity, Asrock and Asus like to put the capacitor drawing on silkscreen the other way around. The filled part of the circle on the circuit board is for positive side of capacitors on their boards.
    • m4a2t0t
      • Mar 2013
      • 276
        ASRock Z97 Extreme6 70-MXGTE0-A01 Motherboard Boardview
        ASRock Z97 Extreme6 70-MXGTE0-A01 Motherboard Boardview...
        10-29-2024, 02:03 AM
      • Exim
        ASRock N100M, no picture no boot, but semi-alive
        by Exim
        Hi guys,
        I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
        ASRock N100M special features:
        - CPU soldered to board, small Intel 12th gen
        - iGPU
        - four POST LEDs
        Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
        I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
        Symptoms:
        - no picture/signal on any of the display connectors,...
        04-01-2025, 02:36 PM
      • MasterCap
        What IC does AsRock usually use to make the PWM signals for GPU fans ?
        by MasterCap
        I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
        Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
        But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
        12-28-2024, 08:42 AM
      • nolaryie
        BIOS .bin file for ASRock B450M Steel Legend
        by nolaryie
        Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
        I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
        Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
        If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
        Thank you!
        08-06-2025, 12:01 PM
      • khanhtq0
        Full BIOS Dump for ASRock H310M-HDV Rev 1.02 (MX25L12873F)
        by khanhtq0
        I'm looking for a full BIOS dump (.bin) for the ASRock H310M-HDV Rev 1.02 motherboard. The BIOS chip is a MX25L12873F (128Mb / 16MB).
        I’ve already tried flashing the official BIOS from ASRock (version 1.40 and 3.30), but those are Instant Flash versions and don’t include the full SPI image (e.g. Intel ME Region, Descriptor, etc.). After flashing, the board powers on only when I short PS-ON to ground, and it fails to generate Vcore and 2.5V. Other rails like 1.05V and RAM voltage are present.
        I suspect the original Intel ME and descriptor...
        08-06-2025, 02:14 AM
