Series for long life on old electronics?
  • gdement
    • Jan 2007
    • 690
    I'm curious about opinions of what's best when recapping old electronics, with the goal being maximum long term reliability.
    I'll be buying some caps from digikey to fix my monitor, and need to pad the order so among other things I'm looking at replacing a cap in an Atari game console (built in late 80's). I had that cap blow up before on an older unit.
    It's an old 8-bit 6502 based machine, so ESR is an unlikely concern. It will sit idle for very long stretches between getting hooked up and used. I'd like it to still be working in 30 years.
    The original input cap is 2200uF 16V, and the pin spacing is such that a 16mm or 18mm cap will fit. I think it sees 12V from the power adapter, maybe a little less.
    I was looking at Nichicon PW, HE, and United Chemi-con LXY, LXZ caps. I suppose any of these are fine, but I'm curious about the practical differences between them when it comes to long life.
    HE has a higher endurance rating than PW (10K hrs vs 8K), but PW has a stated shelf-life spec (1K hrs stored at 105C) while HE isn't stated. I've seen other caps with stated specs at 500hrs, while HE isn't stated at all, so that makes me wonder if HE isn't very good in that department.
    Also, HE is much cheaper than everything else for some reason.
    Between Chemicon LXY and LXZ - does anybody know the difference between these? They look identical. Both have same ESR at equal can sizes, 8K hrs endurance and 1K hr shelf life. The only difference I can find is in some of the available sizes. But if that's the only difference then I don't see why they'd have a different series designation. Might as well merge them under one label.
  • Newbie2
    • Sep 2005
    • 885
    Re: Series for long life on old electronics?
    Use the Panasonic FC series capacitors. They are high reliability low impedance capacitors, and they are perfect for older less-demanding applications.
    Since you requested for a 16MM capacitor, here's the link on Digikey for the Panasonic FC series capacitor: http://search.digikey.com/scripts/Dk...name=P10258-ND
    If you want a longer lasting capacitor with lower impedance than the Panasonic FC series, look at the Panasonic FM series. I found a smaller 12.5MM 2200uf 16V capacitor for the FM series on Digikey, and here's the link: http://search.digikey.com/scripts/Dk...name=P12369-ND
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • gdement
      • Jan 2007
      • 690
      My problem with the FC's is that they have a significantly lower endurance rating (5000 hrs in the big sizes). That's still good, but some of the alternatives are higher (8000-10K hrs).
      Point in their favor is a stated shelf life spec (1000hr@105C), but that's also matched by the LXY/LXZ/PW's.
      • linuxguru
        • Apr 2005
        • 1564
        LXZ is smaller than LXY, LXV, etc., but are otherwise similar. For high endurance without the absolute lowest ESR, any of LXZ, PW, FC, FK or Rubycon ZL, ZLH will do just great - I just use whatever is available.
        Note that if you're using it in a conventional mains transformer-rectifier-filter application, you should avoid using low ESR caps in the filter. YMMV, but the inrush current as well as charging spikes could cause the rectifiers and/or transformer to fail prematurely.
          ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
          This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-12-2024, 03:28 PM
          ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
          This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
          This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
          This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
          This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
