MSI 7525 0B0B post code ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    What's the meaning of 0B0B on POST diagnostic code ?
    It's HP board, I'm not sure if it's AMI or Award BIOS...
  • bianchi77
    • Jun 2016
    • 1121
    Re: MSI 7525 0B0B post code ?
    I"m using Core 2 Duo E6500 as CPU test....could it be another compatibility issue ?
    http://support.hp.com/au-en/document/c01386897
    • bianchi77
      • Jun 2016
      • 1121
      I got missing LAN chip on it....could it be the cause of the issue ? BIOS tried to init this chip and it's missing ?
      • bianchi77
        • Jun 2016
        • 1121
        Is it possible that my northbridge faulty ? It's integrated with VGA
          LCD LED TV Service Menu Codes
          ALL LCD LED TV SERVICE MENU CODES
          Service Menu Code with Board Name
          China Universal Board / Jumper Board Service Menu Code
          Changhong Ruba Service Menu Code
          Ecostar LED TV Service Menu Code
          Orient LED TV Service Menu Code
          Haier LED TV Service Menu Code
          TCL LED TV Service Menu Code
          Samsung LED TV Service Menu Code
          LG LED TV Service Menu Code
          Videocon LED TV Service Menu Code
          Supra LED TV Service Menu Code
          Toshiba LED TV Service Menu Code
          Symphony LED TV Service Menu Code
          Veste/ LED TV Service Menu Code...
          10-31-2024, 03:58 AM
        • dmccul2698
          Pioneer DEX-P99rs "No EEProm " diagnostic code.
          by dmccul2698
          Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
          1). Understand the schematic and check the connections between the EEProm and DSP
          2). Check the functionality of the EEProm
          I don't know if this is the unit's problem but it's a place to start.
          I have little to no electronic experience...
          04-08-2024, 05:32 PM
          Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
          Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
          various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
          Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
          trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
          what is wrong with your PC in just seconds. It saves you time and money.
          Our new and improved design...
          11-01-2024, 06:29 AM
        • Curtissimo
          HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
          by Curtissimo
          Hi everyone.
          I have a HP Elitebook 850 G8.
          Serial: 5CG2324XM0
          ProdID 6L8D5EC#ABA
          It has a Winbond W25Q256JVEN Chip.
          I need to remove BIOS Password.
          I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
          Attached my dump.
          I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
          I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
          What I did:...
          08-26-2025, 04:42 AM
        • Sorrow1
          Intergraph TDZ 2000 mainboard post code 2F/2E
          by Sorrow1
          I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
          It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
          When I recorded video of POST card and played it in slow...
          01-03-2024, 04:13 AM
