Confused with 22mf Caps on soyo sy-p4vgm
  • madscientist132
    • Jun 2016
    • argentina
    I was given a computer with this soyo motherboard. Although some cleaning here and there, it works nicely, but i did not trust the caps despite no bulging neither visible bad symptom.
    As i'm used to do, i got new caps and replaced them one by one. Now, happens that this motherboard takes 4 caps od 22mf*25v, i could replace correctly 3 of them, but i actually seems i confused the other one by a 10mf or a 100mf, that's the reason i wish to ask if anyone could let me know the proper location of the 22mf caps as i actually i have to replace a mistakenly placed one by one of 22mf. At this point, i didn't yet solder them so i fixing this mistake means just taking the wrong one and placing the correct one wherever it has to be done..
  • Sparkey55
    • Jan 2010
    • 1523
    Re: Confused with 22mf Caps on soyo sy-p4vgm
    You should post some photos of the motherboard in question.
    What are the new caps?
    There is more than four caps on that motherboard.
    Do you mean 2200mf or 22mf caps?
    • madscientist132
      • Jun 2016
      • argentina
      Thank you very much.
      I had solved the problem learning that i did not misplace the caps, actually when i soldered them a drop of soldering wire went beyond it's trace close to the 12v connector for the processor and that short circuited the board. now i'm running the computer without any issue so i believe i have no further problems to ask for help.
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
