Is there nothing safe from bad caps???
  • stavr0
    • Nov 2007
    • 21
    This one is a 12V car transformer for a Philips CD player. It stopped working one day, LED no longer lit, no voltage.
    The only large cap in there is WISDOM 1000u 10V 85C, which was connected in parallel to the 5V output. Once I took it out the LED lit again and I registered 5V on the output side.
    I don't have specialized equipment to test it, but doing a simple test: Apply 5V, then use multimeter to measure drain time... well once I took it off the power I never measured anything close to 5 volts.
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    Re: Is there nothing safe from bad caps???
    Wisdom caps, eh? Never heard about it. CD player now works? Have you replaced the caps with something good? Like Panny FM, Samxon GD/GC or Ruby MBZ/MCZ?
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
    • PedroDaGr8
      • Oct 2006
      • 130
      I gotta say. My pioneers i have had in my car used nothing but Elna through out the whole device. Never had a cap problem with them (even when the cd's came out of the drive so hot I could barely touch them.
        by momaka
        03-12-2025, 03:42 PM
      • GraphicMan
        rio volt portable mp3 cd player.What type of caps are these?
        by GraphicMan
        Hello
        this is a rio volt portable mp3 cd player main board
        accidentally its 120ac power adapter was used with 220ac
        the unit worked for few seconds and then off and never worked again
        it normally takes 3volts batts or 4.5dc from the adapter socket
        in the picture I believe this is the main power IC (4 channels)
        it is the only area in the board that barely gets warm after few minutes
        drawing 0.4 watts in total continuously
        i did checked all the caps on the board including these caps around the IC
        nothing is shorted...
        09-11-2022, 07:52 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
