Having to press power button many times to get HP and DELL (desktop) to turn on.
  • mattpd
    • Oct 2012
    • 301
    I have a collection of Dell Inspirons and 1 HP mini pro system (desktops) that do not turn on normally. Occasionally they will work normally but most of the time you have to fiddle with them to get them to turn on.
    To get them to turn on I have to do things like tap the button 20+ times. Or sometimes they will turn on if I hold the button for 5-10 seconds. Sometimes I have to unplug and replug power multiple times before it will work. It also seems like pulling CMOS battery or clearing CMOS with jumper helps things somewhat. This HP will sometimes come on just by plugging in the PSU. At other times they just refuse to come on no matter what you do.
    When they do turn on, it seems you can shut down and turn them on again without problem. The problem only returns if you shut down for an extended time, or you unplug the PSU.
    For some of the Dells, it seems I can bring them back to life by heating up the board first. Then they will turn on/off reliably for a while. No luck with this on the HP.
    Generally, what could cause something like this in desktop computer? The heat fix on the Dells makes me thing a BGA is not making a connection when it's cold, but that's just a theory. BIOS maybe? Any suggestions are appreciated.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Having to press power button many times to get HP and DELL (desktop) to turn on.
    BIOS no way. But could definitely be bad caps. It would help if you posted the models of those systems you are having trouble with.
    A working TV? How boring!
    • mattpd
      • Oct 2012
      • 301
      The HP is a Compaq 8200 Elite
      The Dells are different flavors of Inspiron, from 2011+. I have about 8 of them right now, but none in front of me to get the model number.
      No bulging caps anywhere to be found. In fact most of the caps on these boards are solid aluminum with a few electrolytic ones here and there. I guess it could be a solid cap or an SMD cap that has gone bad though...
