Asus M2V-TVM frustration
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    This had bulging 3300uf 6.3v KZG in VRM output
    Didn't test it first, replaced them with Sanyo WG
    Then tried board - no sign of life
    Reflashed BIOS chip externally - still no sign of life
    Some therapeutic cursing, removed HSF & RAM, to test if Sempron 3000 got warm after power on
    Only mildly so, but then after a few seconds of silent testing, it started getting warmer and "no memory" beeps started
    Replaced HSF & RAM, and it booted up nicely
    Tested, including MemTest86+ and an XP install, without issue
    Left overnight, and you guessed it, next morning dead as a dodo
    More testing without HSF & RAM, no luck this time, then noticed CMOS battery which measured ~2.9v last night, was now ~2.6v
    Put in new battery of ~3.3v and "no memory" beeps straight away
    Then booted fine, and another session of successful testing
    Next day, dead again, and CMOS battery ~2.8v
    Tried another new battery of ~3.2v, no luck
    Put the thing aside before violence started
    Wondering about 1000uf 16v KZG in VRM input ...
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Asus M2V-TVM frustration
    Does it crash when left on?
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Rock solid stable
      This morning it started straight away, although had lost CMOS settings - and battery of ~2.8v which I hot-swapped in last night while testing, was still ~2.8v
      Don't forget, it's Winter here in southern hemisphere, and while unheated garage/workshop/playpen may not get cold by northern hemisphere standards, it's still pretty chilly
      Hot-swapped in another CMOS battery of ~2.9v which retained settings through a brief power-off, and going to replace Sempron 3000 with Athlon X2 3600 to see how it goes
      I quite like Via-powered stuff, compared to nVidia s**t
      • mockingbird
        • Dec 2008
        • 5484
        Almost certainly a northbridge which needs to be re-balled or reflowed.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Yeah. Take off the heatsink and reflow the VIA northbridge. Careful on the temps though, they're sensitive.
          A working TV? How boring!
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            Here's a pic before my first attempt, with a bit of aluminium angle shielding the capacitors
            The stuff around the northbridge is Amtech Syntech-TF - hopefully genuine, although from eBay, it was a vendor in Connecticut USA
            I've had two goes at it - first with hot air station set at 320c, second at 350c, both times fairly slow air flow
            Neither very successful - thinking once more at 370c, before it meets the garbage tin
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              Maybe third time lucky
              I tried another reflow yesterday at 370c, after which it booted immediately
              Left overnight, this morning it booted straight away again - with CMOS settings retained, and battery not discharged
              Tested a clean install of XP without problems, it's now run Aida64 System Stability Test for ~2 hours
              My thanks to mockingbird and Th3_uN1Qu3
