Soyo with Emax PWR0502204001 Caps
  • teratosis
    • Jul 2015
    • 4
    • usa
    He there I have a Soyo with an Emax PWR0502204001.
    Trying to find the name of the following caps(attachments), but I can't determine what they are.
    And the schematic on this page is too small for my bad eyesite.
    http://www.emax-co.com/english/produ...23&sup_no=1714
    Can someone please help me identify the caps on the attached image?
  • c_hegge
    • Sep 2009
    • 5219
    Re: Soyo with Emax PWR0502204001 Caps
    That is not a proper schematic on that page, and it doesn't tell you what the caps are. All it tells you is the physical dimensions of the PCB. You will have to take the board out and see what your one has.
    • chocolate-fuse
      • Oct 2018
      • 3
      They are 16V 1000uF for anyone coming across this now. I have the same board and these failed, replacing them gave it another 2 years of life.
      Now unfortunately it blows the household circuit breaker when connected to the mains so I'm trying to figure out what else has failed on the board!
      • chocolate-fuse
        • Oct 2018
        • 3
        I can't edit my post unfortunately.
        Does anyone know what voltage the backlight LEDs run at? I am wondering if I could hook up a 12v and 5v supply to the monitor and use them to directly power the video board and backlights.
        Does this sound sensible? I can't find anywhere to get a replacement board.
        • brethin
          • Dec 2008
          • 1907
          3 year old Necro posting, start a new thread give lots of pics and ask a detailed question.
          • brethin
            • Dec 2008
            • 1907
            FYI if it's blowing a household breaker it because you have too much load on that breaker.
            • chocolate-fuse
              • Oct 2018
              • 3
              Thanks, I'll do that.
              When I say it blows the household breaker, I mean it gives off a loud bang, the integrated fuse blows across the room and the breaker flips. I presume there is a dead short on my board but my electronics knowledge + multimeter is not good enough to diagnose it. I will make another post in this forum.
                by momaka
                03-12-2025, 03:42 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
              • Foetuss
                Gigabyte GA-6OXT :: caps question
                by Foetuss
                Good evening
                I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                But I was also suprised about the bigger boys, which are 330µF 25V.
                Could it be they used 25V caps because they were cheaper / available at that time?...
                02-11-2025, 12:22 PM
