Gigabyte 7VT600P-RZ?
  • djpc47
    • Dec 2007
    • 17
    anyone recap any Giga 7VT600P-RZ, seems like a nice board but dunno what wrong... replaced some of the caps with some caps from some other dead boards.... it gets to a point where the cpu fan spins, 2 mosfets get 5volt input other 2 get no input no output....
    can anyone tell me of there experience with these boards?
    sidenote, first time I try going any further then replacing caps on a working board:P... little electronics knowledge, good soldering experience:P
  • hardwareguy
    • Jun 2006
    • 405
    Re: Gigabyte 7VT600P-RZ?
    Check for shorted caps..... try new capacitors. Usually a short will shut down the PSU though.....
    Also, check for burned traces and recheck the solder joints.
    • hardwareguy
      • Jun 2006
      • 405
      Oh yeah...check the PSU connector.
      • starfury1
        • May 2006
        • 1256
        none with this MB
        Suppose the first question was it booting up before you change caps?
        how bad to look at and what brand series were they?
        but yeah recheck work as above if it was booting before hand
        you say you used "used caps?"
        (ideally not a good idea)
        from a photo image I found it uses (I think 2 phase VRM)
        (link for ref only)
        There is usually (for want of the correct technical terms ) a top and bottom Mosfets pairs
        So 2 I think should have voltage but 2 wont have voltage (per say)
        So that sort of sounds right
        are any mosfets getting very hot? per chance
        There can be a few reasons why it wont start up and the state it was in before recap can help work this out.
        So a bit more info might help us help you
        Cheers
        • djpc47
          • Dec 2007
          • 17
          it was given to me dead by a friend.... apparently he had it hooked up at the time and running.... he went to go to use his computer and it was off he tried to turn it on but nothing.... series of caps I replaced... don't remember to tell ya;P sorry.... I will say though there is a chance his psu was shotty and may of been the cause
          • djpc47
            • Dec 2007
            • 17
            just noticed on the backside of the board its a bit yellowed where the mosfets are and same where where the north bridge is...
            guess its done
            • DynaxSC
              GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
              by DynaxSC
              I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
              General test conditions:
              - Tested with Core i5 6500 and Core I7 6700K - no difference
              - Default BIOS settings, but tried also altering several memory setting - does not change anything
              What is wrong:
              With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
              When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
              03-21-2025, 06:23 PM
              Thermal pad thickness for various laptop GPU / Graphics Cards
              ASUS Dual RTX 2070 OC 8GB
              ASUS ROG STRIX RTX 3080 OC
              ASUS ROG STRIX RTX 3090
              ASUS TUF Gaming RTX 3080 OC Edition
              ASUS TUF GTX 1660 S-O6G GAMING
              EVGA RTX 3060 Ti XC GAMING 8GB
              EVGA RTX 3060 XC GAMING 12GB GDDR6
              EVGA RTX 3080 FTW3 ULTRA GAMING
              EVGA RTX 3080 TI FTW3 ULTRA GAMING
              EVGA RTX 3090 XC3 ULTRA GAMING 24GB
              Gainward RTX 2080 Phoenix GS Specs
              Gainward RTX 3070 Phoenix 8GB
              Gainward RTX 3080 Ti Phoenix
              GIGABYTE AORUS RTX 3080 MASTER 10G
              02-09-2024, 08:08 AM
              A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
              by momaka
              More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
              And a shot of the label:...
              01-26-2022, 03:26 AM
            • nikovmiroslav
              Gigabyte A5 X1 Need Bios
              by nikovmiroslav
              Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
              Gigabyte A5 X1
              From motherboard:
              S/N: 1TNH55ER1350895
              P/N: 6-77-NH55ERQY-D02-2CGB
              On sticker from the back of the laptop:
              S/N: SN21351J000657...
              08-24-2025, 09:15 AM
              Gigabyte AERO 16 XE5-73UK948HP Notebook Specification for Upgrade or Repair
              This specification for the Gigabyte AERO 16 XE5-73UK948HP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 XE5-73UK948HP boardview and 16 XE5-73UK948HP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-07-2024, 07:19 AM
