Again, going to start another recap job with a MSI P4M900M2 (MS-7255) motherboard. But before I start, can I replace the original 16V 1000uf with a 16V 1500uf caps? The caps are located near the CPU. Currently that the only 16V caps i got.
Msi p4m900m2 (ms-7255)
Re: Msi p4m900m2 (ms-7255)
yes it's ok the use that caps because it's ok to use upper or equal voltage and capacitance but not lower -
When i got this motherboard, it looks to me there are 4 x unknown capacitor been exploded, what left is just 2 leads on each of the exploded capacitor.
I did found a schematics for this board, and found out the value of the missing caps are 16V 1000uf. What I got in hand are a few 16V 1500uf Nichicon HN(M) caps that i salvage from a dead Xbox main board.
After replacing those missing caps, the motherboard is able to POST, but during the installation of Windows 7 I constantly getting IRQL_not_less_or_equal BSOD . After a few tries, I finally able to successfully install Windows 7 on it. But I still getting the same BSOD message randomly when I was using the motherboad. I am thinking there must be some reason why the capacitor was exploded previously and caused by a faulty PSU maybe
and other component might been damaged. The next morning I turn on the motherboard again and no BSOD this time and able to install all the driver. But instead of giving me BSOD it will randomly restart itself for no reason. I have run memtest86 on this board and completed for a few pass with no errors.
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
Channel: General Capacitor Questions & Issues
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
