Anker 71an7105 Usb power adapter - blown fuses
  • clearchris
    • Dec 2013
    • 687
    These are great little power supplies, except that are known for blowing fuses. The newer model has resettable fuses, so after 3 blown fuses, it was time...
    Original with fuses:
    After adding resettable fuses:
    Not the prettiest, but considering the size of the new fuses vs the old ones, not too bad really. Each port is rated for up to 2.5a, I chose a 1.6a resettable fuse that throws at about 3a.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Anker 71an7105 Usb power adapter - blown fuses
    Nice fix!
    By the way, what brand caps are in the PSU? Could we maybe get a pic of the topside of the board?
    -Ben
    Muh-soggy-knee
    • clearchris
      • Dec 2013
      • 687
      You got it.
      Top, bottom.and close ups of caps.
        • 31296
        you need to resolder the bridge rectifier & power inlet.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Wow, that is better than I expected! They even used polymer caps!
          Muh-soggy-knee
          • clearchris
            • Dec 2013
            • 687
            sti: Is that because they are a little light on solder or do you see something else?
            ben7: Yeah, aside from the fuses, it's not a bad device. I was surprised to see what appears to be polymer caps as well. These came pretty cheap too, on sale for like 15$ or so. They do up to 8A across 5 ports with 2.5a max from any 2 ports at a time.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              nice ring cracks.
                • 31296
                Originally posted by kc8adu
                nice ring cracks.
                exactly, the solder is cracked.
                • clearchris
                  • Dec 2013
                  • 687
                  Hmm, thanks for the heads up. I took a closer look and couldnt tell if they were cracks or some kind of residue . There were certainly rings of some sort. I removed the lead free solder and used some 63/37 instead. Nice and shiny now.
                  • clearchris
                    • Dec 2013
                    • 687
                    Newer version of the power adapter.
                    This version seems constructed for easy replacement of fuses, the board has more room for the fuses (still not resetable) and the board has slots underneath the fuses so its a lot harder to solder it in wrong. The solder on the board is a different alloy, it requires a LOT more heat to melt.
                    Resetable fuses soldered in:
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Nice! Now they should use a synchronous rectifier on the output :P
                      Muh-soggy-knee
                      • airsky98
                        • Sep 2015
                        • Singapore
                        what part number should i buy for the resettable fuse ? i have one lying around, got it from HK last year, too troublesome to get it fix.
                        • clearchris
                          • Dec 2013
                          • 687
                          Sorry, didn't see the reply. Probably late, but here's what I bought.
                          Digikey:
                          652-MF-NSMF150-2
                          MFG Part No:MF-NSMF150-2
                          MF-NSMF150-2
                          Bourns Resettable Fuses - PPTC
                          US HTS:8533290000 ECCN:EAR99 COO:CN
