Hello friends,
Today's project is a Precision 380 motherboard. It's a "newer" machine, at least I'd consider it to be that (even getting on at 8 years old now...) in comparison to the more commonly plagued Precisions.
Quick side note: I have a Precision 390 as well (Core 2 Duo board as opposed to the 380's Pentium D/4 board and 955 chipset) and It had four blown caps right in the center of the board. It would restart *with error beep* (note!) and was absolutely random on whether it would detect any stick of ram in any slot at any given time. Replaced those four caps and it has been running nonstop for a good month now.
When it would die and beep, it was useless until you removed power (or held the button) and tried again. This also left a log in the BIOS that a "Thermal event has occurred" (if I remember correctly) which was bogus, the thing was spotless and had fresh Arctic Silver everywhere!
This 380 has a similar problem. A machine new to me, I slapped a hard drive in it and popped in the Dell Win XP disk. It didn't even make it past the file loading sequence before a faint click click... and it rebooted.
However, there was NO error message (diagnostic LED sequence) or new item in the diag log (BIOS). Just like you'd hit the restart button (if it had one of those).
Look in the center of the motherboard (nearly identical, again only chipset appears different) and whaddya know - four perfectly-good-looking Rubycon MCZ caps. Wait... Huh?
I have attempted to run Memtest86 (and +) and other memory tests, and it will reboot within a few seconds of the start. Never errors, just reboots.
Power supply appears fine but it is cramped and I can't see the actual cap brands.
Every cap on the board *looks* fine, but of course that might not be the case. Fortunately (or unfortunately, however you look at it) there are nine Chemicon KZG caps, two are located near the 4-pin 12v connector, four are below the CPU but obviously not quite in direct contact with it, and the other three are hiding between some of the PCI/PCI-e slots.
I hear these KZGs are bad. Heck, the post thread below me at this moment is for an XPS with similar cap choices. I also found a blog post a bit ago (and now lost it...) where the writer replaces four KZGs (with nice shiny flat tops, lookin' good) to repair a motherboard (however these were right next to the CPU).
EDIT: I just found one of the bad/replaced caps from the 390 I spoke of, and it is a Chemicon KZJ.
I'm going to look for replacements today and see how that goes. I definitely want to get all of those out of there if they're -that- bad.
There's some other small Chemicons scattered around the board, but they're all KY. I'll leave those be for now.
EDIT: Dur... The two black Chemicons in the top right are KZJ. For some reason it didn't click earlier. Looks like they gotta go, too!
Pictures attached.
Pictures attached.
