Asrock P4I65G
  • davmax
    • Dec 2005
    • 899
    Asrock P4I65G
    I had to replace a motherboard with this Asrock. My first experience with Asrock is not good. The board is full OST caps with the exception of Sanyo caps at VRM input. The manual is very sparse with no bios information except how to open to set up.
    I was tempted to change at least the VRM output caps, however it is a system for another user and under warranty. We will see how it lasts!!!
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    Samsung 18x DVD writer
    33 way card reader
    Windows XP Pro SP3
    17" Benq FP737s LCD monitor
  • gabrieljma1
    Request: Full BIOS dump for ASRock Z790-CX (DDR5)
    by gabrieljma1
    I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
    The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
    I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
    10-08-2025, 03:32 PM
  • Erroneous Hyphen
    AsRock P4i65G polycap/polymod advice?
    by Erroneous Hyphen
    Hello!
    I have a Pentium 4 motherboard, a AsRock P4i65G that I'm wondering whether it would be worthwhile doing a polycap upgrade on? The existing capacitors look fine to me, none are bulging or leaking that I've noticed. I was approaching it more from an 'upgrade' perspective, as to whether there would be any benefit to do such a mod even if the existing capacitors look fine?
    I believe that if I do go down this route, for the Voltage Regulation circuits that I should be sticking to the same capacitance and voltage, and that a higher ripple voltage and lower ESR can...
    04-03-2022, 07:41 PM
  • DOBBELDUNK
    NEED Bios File ASROCK H61M-VS4 REV.G/A 1.01
    by DOBBELDUNK
    Mobo turn on, HSF on but no display, blank only in monitor.
    Here is bios backup of asrock h61m-vs4 rev. g/a 1.01
    11-20-2025, 10:07 AM
  • Exim
    ASRock N100M, no picture no boot, but semi-alive
    by Exim
    Hi guys,
    I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
    ASRock N100M special features:
    - CPU soldered to board, small Intel 12th gen
    - iGPU
    - four POST LEDs
    Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
    I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
    Symptoms:
    - no picture/signal on any of the display connectors,...
    04-01-2025, 02:36 PM
  • MasterCap
    What IC does AsRock usually use to make the PWM signals for GPU fans ?
    by MasterCap
    I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
    Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
    But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
    12-28-2024, 08:42 AM
