ASRock Z77 Extreme 6 not powering up
  • orientalsniper
    • Apr 2013
    • 459
    Hello, I could use some help trying to fix this motherboard, so I get 3.4V in PWRSW and I also shorted the PSU to feed power to motherboard by force and I don't feel any heated part.
    Could the problem be in the SIO chip or southbridge/northbridge?
    UPDATE:
    Only 5V in PIN9 (+5VSB) and 5V in PIN16 (PSU_ON#) of PSU connector.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: ASRock Z77 Extreme 6 not powering up
    Lets rule out the psu first, do you have another psu to check the board with ?
    • orientalsniper
      • Apr 2013
      • 459
      Yeah, I've tried different PSU/processor/RAM.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ok sounds like something on the board, firstly check the board all over for any shorted pins for example on the pci slots if there is nothing obvious then I will tell you what to check next.
        Also check things like the usb ports and ram slots, we need to narrow this down.
        • orientalsniper
          • Apr 2013
          • 459
          Yeah, man, I already checked those: USB, SATA, Firewire, LAN, HDMI, PCI, PCIe, RAM.
          • orientalsniper
            • Apr 2013
            • 459
            Checking resistance with ATX power connector against ground:
            3.3V: 265 ohms
            5V: 515 ohms
            12V: 3 kohms
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Sounds like a short, firstly check the cpu vrm mosfets as they normally go first check all the mosfets for resistance just check them all and see if any of them check different from the majority of them.
              • orientalsniper
                • Apr 2013
                • 459
                Sorry, what do you mean by resistance? Gate/Source/Drain against ground?
                I did test the coils near the vrm mosfets and so far it's not shorted against ground though.
                • david38c63
                  • Oct 2011
                  • 4
                  I would start looking for bad caps that esr is too high on in the 3.3v supply and 5 volt stand by
