980TI Jetstream | vCore no heating up
  • Lazaros Karypidis
    GPU Repair Noob
    • Nov 2024
    • 6
    Hello Community,
    I am in the process of repairing a Palit 980TI Jetstream. Before that, the GPU was running with new drivers. But as soon as I started a benchmark (or a game) it went off, but the computer stayed on.
    I then wanted to check the phases to see if they switch when there is a load on the card. But I slipped with the measuring tip and (I assume) caused a short circuit on the NCP81162 (phase doubler) (marked green in the photo).
    Since I wanted to be on the safe side, I replaced all three NCP81162 and the PWM controller NCP81174.
    Unfortunately, the VCore no longer warms up from this point on and I also get no picture. Now I have searched the net for the boardview, because the ones from MSI and Asus don't fit, but I couldn't find one to understand how the paths of the individual chips run and what hangs in between to check this.
    I want to ask if you could give me a tip on what else I should/can check and if any of you have a boardview of this one card.
    Do you need accurate measurement results? If so, which PINs do you want to know?
    Everything I have changed is marked in red
    Many thanks
    Lazo
  • barry101
    Apple 820-3662 VCore shorted to ground.
    by barry101
    Hi, Would appreciate some help.
    I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
    Get charger light but no fan spin or chime. No liquid damage.
    Found PPBUS and VCORE both shorted to ground. Other rails were ok.
    Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
    With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
    Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
    06-24-2025, 07:34 AM
  • c_corr
    Asus P4C800-E VRM issues
    by c_corr
    This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
    This board uses mext ICs and Mosfets in VRM:
    - ADP3180 PWM controller - in 3 phase mode
    - ADP3418 as Modfet drivers
    - High side Mosfets STD38NH02L (from ST)
    - Low side Mosfets STD90NH02L
    Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
    I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
    02-08-2025, 11:59 PM
  • Francisco.s
    CPU vcore missing in HP workstation Z2 Mini 4G
    by Francisco.s
    Hi, have a HP workstation Z2 Mini 4G for repair with CPU vcore missing.
    The resistance at the output of CPU vcore coils, is less than one ohm so I think CPU could be damaged, but no mosfet are damaged.
    It mounts an i7 8th gen, and have only i5 7th gen for test, but I think it is not compatible.
    Without CPU in the socket there is no short, but there is no vcore voltag, and it emits a beep like no detecting ram.
    The controller chip for cpu vcore is a MP2949A, and has no enable voltage at pin 37.
    I wonder which circuit generates this enable...
    04-22-2024, 12:35 PM
  • EasyGoing1
    The best way to drive a heating element?
    by EasyGoing1
    I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
    What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
    This is the general setup that I have now.
    This is what the...
    01-25-2023, 11:29 AM
  • Cemal Odabasioglu
    MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
    by Cemal Odabasioglu
    I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
    Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
    Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
    Observations...
    01-14-2025, 03:54 PM
