ASUS ROG STRIX B550-F GAMING — Board not powering on properly
  • ShadowAi12
    • Jan 2022
    • 5
    • Poland
    I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
    • The board enters a "ready to power on" state after plugging in the PSU.
    • Pressing the power button increases power draw.
    • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
    Measurements:
    (taken after pressing the power button, while the board is attempting to start)
    • H_SKTOOC# = 0V
    • O_RSMRST# = 0V (but 1.8V while in standby)
    • O_SLP_S3#_R = 3.3V
    • O_IOPWRBTN# = 3.3V
    • O_KBRST = 3.3V
    • PSON# = 0V
    • S_RTCCLK = 3.3V, 500–600 kHz square wave
    • LPCCLK1 = 3.3V, no waveform
    • LPCCLK0 = 3.3V, no waveform
    • LFRAME = 3.3V, no waveform
    • PCIE_RST_L = 0V
    • VDDQ, VTT, VDDP = not present
    • Standby (before pressing power button, including the ATX PSU emulator module): ~120 mA
    • After pressing the power button: ~760 mA (including the ATX PSU emulator module)
    There is no visible activity on the LPC or SPI buses.
    The board does not proceed to full startup.
    Do you have any ideas what else I could check, or what might be damaged?
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • DynaxSC
    ASUS STRIX Z490-F GAMING - No POST, stubborn board
    by DynaxSC
    I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
    The situation looks like this:
    After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
    1. RTC oscillates normally (32.768KHz).
    07-08-2022, 05:45 AM
  • slimmy182
    MacBook M1 Pro 14" 2021 A2442 (820-02098) — U2020 getting hot, board not powering on
    by slimmy182
    I have a MacBook Pro M1 14” (board 820-02098) with a broken LCD panel (matrix damaged).
    The board does not power on — when connected to power it draws about 5.1 V / 0.474 A (~2.45 W) and stays at that level, with no fan spin or display activity.
    Using a thermal camera, I noticed that U2020 heats up to over 70 °C shortly after connecting power.
    According to the schematic, U2020 is a SN74AVC2T45RSWR (Texas Instruments) 2-bit bidirectional level shifter.
    There are no visible signs of liquid damage anywhere on the board.
    Given the broken LCD,...
    08-15-2025, 02:57 AM
