Inno 3d RTX2070 not detected - no I²C connection
  • Nikan.e
    • Nov 2023
    • 17
    Greetings and Salutations!
    I have encountered a faulty GPU — an Inno3D RTX 2070 Twin. There was a shorted MOSFET on the Vcore rail.
    The faulty DrMOS was removed, and the burned PCB area was milled away.
    All voltages are now good, but the GPU is not being detected.
    I found that the CS pin of the BIOS (GPU) is not being pulled low, and thus, the GPU isn't detected.
    I wanted to measure the SM_Data and SM_Clock, but to my surprise, there is no connection at all.
    I thought these pins were used for communication during startup?!?
    On all the other cards I have on hand right now and have inspected, there is indeed a connection—either through some vias or traces on the board.
    However, the GPU I am working on right now doesn't seem to be using these pins at all.
    What is going on here?
    Is detection being done through the first PCIe lanes on modern cards?
    Any explanation or help in figuring out the fault and working principle of the card would be greatly appreciated!
  • spacez
    XPS 15 9520 - tpm device is not detected - NO ssd detected
    by spacez
    I have an XPS 15 9520 with a damaged bios so I flashed another one from badcaps. in manufacturing mode I changed the service tag but unfortunately ssd is not detected and also the error -tpm device is not detected- please help me. I haven't changed the tpm chip yet. Thanks in advance
    Service Tag: J2MSHW3
    |Express Service Code: 41518077843
    mother board LA-L402P REV 1.0(A00)​...
    08-18-2024, 10:54 PM
  • budwich
    Lithium 12v tool battery charger... no negative connection?
    by budwich
    I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
    03-18-2025, 09:12 AM
  • superdota2
    HP 15s-FQ2552TU nvme drive not detected
    by superdota2
    HP 15s-FQ2552TU
    da0p5hmb8f1 rev f
    sn# 5CD138CCH4
    problem is power on but no display,no bios post
    i search bios here ,i found and it work and got display.
    https://www.badcaps.net/forum/showthread.php?t=104925
    second problem is nvme drive not detected in bios intel rapid storage,
    i tried a working nvme drive but still not detected in bios,
    also tried install system and install intel rapid driver,still not detected....
    06-21-2023, 09:36 PM
  • Scotchmist
    Lenovo thinkpad 15 itl g2 - No Hdd detected
    by Scotchmist
    Hi
    I got this laptop with bad onboard ram so edited the bios with SPD removal tool to disable the onboard ram and work with the ram slot - the laptop now posted so i thought all was good however when i put everything back together it will not boot to windows as no boot device found., In the bios is says hdd not detected, i disabled VMD in the bios but still the same, loaded windows on usb stick and windows install cannot find the hdd. I bought a second board that had water spill, repaired the damaged area and it posted ok but same issue no hdd detected.
    I have now tried...
    09-11-2024, 05:06 AM
  • titomno2
    Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
    by titomno2
    Hi guys,
    On motherboard ACER AN515-52 type LAF951P.
    I fixed issue with not starting computer (it was the PQ201 component not working properly).
    But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
    Basically some HDD spin but are not detected by the bios.
    Already tried following:
    checked the 4 data lines
    #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
    #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
    07-28-2024, 08:30 AM
