Resistances of V-Core and V-RAM for AMD Radeon RX 6900 XT
  • AllElectronicsRepairs
    • Feb 2020
    • 21
    Hi Guys, what should be the resistances to Ground of V-Core channels and V-RAM for AMD Radeon RX 6900 XT? Is 67.9 mOhm for V-Core OK? I am trying to diagnose this Graphics Card and check for any shorts first. Like none of the power rails seem to be shorted, but I want to make sure before injecting any (low) voltage to see if any component raises its hand... Kind regards, Jerry..
  • FriedFred
    • May 2024
    • 137
    It's quite difficult to diagnose a short at a CPU or GPU. There are thousands of transistors in parallel, this keeps the "ON"-Resistance very, very low. So, usually, with a standard-multimeter, it's not possible to make a correct diagnose on a CPU or GPU. I have had "dead" GPUs and they worked just fine after removing of the real short maker...
    You can diagnose a short with a controlled electrons injection also at CPU and GPU core level. Those cores use a voltage up from 0,65V. So if you use a voltage not higher than 0,5V, all is nice in this delicate areas. If you have a short or at least a higher current consumption with this low voltage, then really something is wrong.
    • DynaxSC
      • Apr 2021
      • 458
      • Poland
      To measure VCORE resistance on a GPU u need a milliohm meter. It has a slightly different design compared to a standard DMM and uses 4 wires from meter to probes (2+2). So it is able to compensate the wire resistance when measuring very low resistances. I'm not sure what should be the resistance for a RX6900XT, but for a healthy GTX1070 it is in the range of 150-200 mohm. You can buy some milliohm meters on AE, and they are affordable and do the job. Anybody dealing with GPU repair I'd recommend to have one, as it helps to check GPU very easy and fast.
      If you have a high quality DMM with a very high resolution (4 or 5 digits), u might also do two measurements, first the GPU resistance, second the probe short resistance, and then substract from the GPU resistance the probes short resistance to get the real GPU resistance. However normal DMM's have a too low resolution as they can measure usually not better than in 100 mohms steps, so not enough to have a qualitative result.
        • Feb 2020
        • 21
        Thank you for your reply. Yes, I do have a milliohm meter and Kelvin probes (4 wire probes) that eliminate the need to measure wires resistance. I am pretty experienced electronics repairer (8 years) but modern graphics cards are NOT my usual repair devices. That is why I asked a SPECIFIC question, hoping for a SPECIFIC answer from somebody, who knows.
        A tak poza tym, gdybyś przeczytał uważnie mój post, dowiedziałbyś się, że byłem w stania zmierzyć 67,9 miliohms, więc muszę mieć możliwość dokładnego pomiaru tak małych oporności. Ale dzięki za odpowiedź - i tak jestem wdzięczny. Pozdro, Jarek.
        • DynaxSC
          • Apr 2021
          • 458
          • Poland
          Hejka, miło poczytać coś po polsku, i to z tak daleka. Pozdrawiam. Czarek.
            AMD Radeon RX 6900 XT (RX6900XT) Schematic & Board View
            The Radeon RX 6900 XT is an enthusiast-class graphics card by AMD, launched on October 28th, 2020. Built on the 7 nm process, and based on the Navi 21 graphics processor, in its Navi 21 XTX variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 6900 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 21 graphics processor is a large chip with a die area of 520 mm²...
            10-01-2024, 12:18 PM
            AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
            The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
            10-01-2024, 12:46 PM
            AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
            The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
            10-01-2024, 01:07 PM
            AMD Radeon RX 470 / RX 580 Schematic & Board View
            The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
            10-01-2024, 12:52 PM
          • duxzero
            Request: MSI Radeon RX 6900 XT Gaming Z/X Trio schematic and boardview
            by duxzero
            Does anyone happen to sit on schematic and / or boardview files for MSI Radeon RX 6900 XT Gaming Z/X Trio? The layout is a bit too different from the reference card and the Asus/Asrock/Gigabyte schematics/boardview files that are out there.
            04-24-2025, 12:23 PM
