AMD Radeon RX 6900 XT (RX6900XT) Schematic & Board View
    AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
    The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
    10-01-2024, 12:46 PM
    AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
    The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
    10-01-2024, 01:07 PM
    AMD Radeon RX 470 / RX 580 Schematic & Board View
    The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
    10-01-2024, 12:52 PM
  • duxzero
    Request: MSI Radeon RX 6900 XT Gaming Z/X Trio schematic and boardview
    by duxzero
    Does anyone happen to sit on schematic and / or boardview files for MSI Radeon RX 6900 XT Gaming Z/X Trio? The layout is a bit too different from the reference card and the Asus/Asrock/Gigabyte schematics/boardview files that are out there.
    04-24-2025, 12:23 PM
  • AllElectronicsRepairs
    Resistances of V-Core and V-RAM for AMD Radeon RX 6900 XT
    by AllElectronicsRepairs
    Hi Guys, what should be the resistances to Ground of V-Core channels and V-RAM for AMD Radeon RX 6900 XT? Is 67.9 mOhm for V-Core OK? I am trying to diagnose this Graphics Card and check for any shorts first. Like none of the power rails seem to be shorted, but I want to make sure before injecting any (low) voltage to see if any component raises its hand... Kind regards, Jerry..
    01-28-2025, 09:47 PM
