Radeon HD3870 X2, Identify Component
  • Byte_76
    • Apr 2024
    • 44
    • Namibia
    I have a Radeon HD3870 X2 which has all voltages and cores get warm but the card is not detected by the PC.
    There is this component on the PEX reset line but I don't know what it is and what the pinout is.
    Can anyone help me to identify the component?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3590
    • slovakia
    it should be and gate working as PEX RST buffer
    • Byte_76
      • Apr 2024
      • 44
      • Namibia
      Okay, yes but is there a reference to a part number that will have the identical functionality?
      i want to look up the data sheet and order replacements but I need to be sure it’s the correct part.
        • 20807
        The image is blurry, clean the IC with some IPA and see if you can read the marking
        • alindumitru46
          • Aug 2015
          • 255
          • Romania
          Byte_76 take a photo with the light at the right angle, the reflection will help reveal the letters and numbers
          • Byte_76
            • Apr 2024
            • 44
            • Namibia
            I have taken more pics with slightly different lighting angles on each.
            • Byte_76
              • Apr 2024
              • 44
              • Namibia
              Tested in multiple PC’s. The card is not detected by the PC. Both cores do get hot.
              I’m still a novice at graphics card repair so I’m not sure what to check or where to check on the board for voltages or faults.
              • Byte_76
                • Apr 2024
                • 44
                • Namibia
                I’ve circled the location of the components that I am asking about in this thread.
                • Byte_76
                  • Apr 2024
                  • 44
                  • Namibia
                  Any ideas?
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3590
                    • slovakia
                    just use any and gate from literally any gpus. all use the same pinout
                    • Byte_76
                      • Apr 2024
                      • 44
                      • Namibia
                      Thanks. Would this be a suitable replacement?
                      SN74LVC1G08DBVR
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3590
                        • slovakia
                        yes
                          AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
                          The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
                          10-01-2024, 12:46 PM
                          AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
                          The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
                          10-01-2024, 01:07 PM
                          AMD Radeon RX 470 / RX 580 Schematic & Board View
                          The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
                          10-01-2024, 12:52 PM
                          AMD Radeon R7 340 / R7 430 Schematic & Board View
                          The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
                          10-01-2024, 12:36 PM
                          AMD Radeon RX 7900 XT (RX7900XT) Schematic & Board View
                          The Radeon RX 7900 XT is an enthusiast-class graphics card by AMD, launched on November 3rd, 2022. Built on the 5 nm process, and based on the Navi 31 graphics processor, in its Navi 31 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 7900 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 31 graphics processor is a large chip with a die area of 529 mm²...
                          10-01-2024, 12:20 PM
