Galax 3090 bad duty cycle on mem phase
  • pedrolopesbe
    • Dec 2024
    • 10
    • Brazil
    I got this 3090 wich I own, same board as the common 388_50 boardview.
    I'm new to SMD work, and in a moment of stress trying to solder a 0402 filter cap that I've knocked out I've made a big solder mess in the "U42" drmos.
    As past is past, after getting a pre heater now I succesfully unsoldered the chip but I'm having problems soldering it back again.
    At the last time I've worked on it, I had to reflow it as it was not giving any out signal, measuring using the Hz function in my multimeter.
    Now I get a reading of something like 1.7kz while other phases 3.09khz if I'm not mistaken.
    Voltages and PWM seems to be getting to the chip fine, I could measure again to be sure, but it's the same chip that controls the other ones, right?
    One little thing: I can't measure the 27MHz crystal, don't know why... (I'm using a needle tip attachment, but the phases measure fine)
    The card boots and gives video, but artifacts when driver is loaded.
    Looking for some guidance, where to look at...
  • piernov
    • Jan 2016
    • 4435
    • France
    Phases are switching at several hundred kHz. Look at the spec sheet of your multimeter. Need an oscilloscope.
    • pedrolopesbe
      • Dec 2024
      • 10
      • Brazil
      My multimeter reads up to 30mhz, its a hikari 2090
      I'm not buying an oscilloscope right now, if I really need one I could rent it.
      But I don't think one would make or break this repair, right?
      • pedrolopesbe
        • Dec 2024
        • 10
        • Brazil
        I've tried soldering a new drmos in place.
        Phase measure fine but still getting artifacts, didn't measure it again to see if the phase died again (the past time I've had a bad hz reading, the card booted but then the phase died, so its an option.)
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3553
          • slovakia
          dont bother u have bad core. if u have bad memory 3090 will not give picture
          • pedrolopesbe
            • Dec 2024
            • 10
            • Brazil
            bruh, I hope not. The card didn't show any problems before the shitshow I've made.
            I'll be sending this board to a professional when the guy responds me.
            • pedrolopesbe
              • Dec 2024
              • 10
              • Brazil
              Oh, something I didn't mention before: I had errors on all mem bank other than C and D if I'm not wrong while the phase was out. With the phase I get no errors but any test that stress the card fails. Not sure if it would help tho.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3553
                • slovakia
                what u write dont make sense. better measure it again with scope
                • pedrolopesbe
                  • Dec 2024
                  • 10
                  • Brazil
                  The gpu phases reads 3.09khz, mem reads 3.89khz, what doesn't sound right about it?
                  For renting a scope I'd need a valid enterprise registration and having problems with mine right now. If there's the need of one to be sure, I'll just send the card to someone that knows what he's doing 😫
                  • pedrolopesbe
                    • Dec 2024
                    • 10
                    • Brazil
                    Something came through my mind: Maybe, some other mem phase got shorted while running the card with one less phase.
                    I've tried the short finder method dicky96 teached in his youtube channel. (https://www.youtube.com/watch?v=P_2GGNr4q1s)
                    There's these test points for the DRMOS:
                    Click image for larger version  Name:	Screenshot (3).png Views:	0 Size:	59.8 KB ID:	3560841Click image for larger version  Name:	2025-01-31-03-04-34-131.jpg Views:	0 Size:	638.1 KB ID:	3560843 Click image for larger version  Name:	2025-01-31-03-10-30-794.jpg Views:	0 Size:	711.6 KB ID:	3560842
                    Measuring the U17 DRMOS gate test point to the inductor showed 1.13V drop while the three others 1.33v drop. I'll be replacing this DRMOS in hope this may solve my problem!
                    I supose the other mem phase that received 12V from the psu got overwhelmed and got shorted or damaged. (there's 4 phases, 2 get power from pci and two from psu)
                    I'll be back for updates.
                    • pedrolopesbe
                      • Dec 2024
                      • 10
                      • Brazil
                      I'm back for updates!
                      Well, for a change I did fucked it up again lol. The new DRMOS I've installed in the other phase now doesn't work as well, nice
                      I've tested the frequency again and found out that the phase that I've said was working had a unstable frequency and wrong duty cycle compared to the other 2 mem phases on the pci power.
                      Seems like I gotta get my soldering together, this card ain't going to repair it self!
                      I wonder why the one drmos I've "successfully" soldered is giving out the wrong signal.
                      I think you guys can agree with me that the problem won't be in the controller, correct?
                      Short finder still shows a lower reading in the U17 drmos I've mentioned above.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3553
                        • slovakia
                        check input signal. u can have bad controller
                          NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                          The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                          10-02-2024, 08:52 AM
                          DELL OptiPlex 3090 OptiPlex 3000 i5-1145G7 Specification for Upgrade or Repair
                          This specification for the DELL OptiPlex 3090 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3090 boardview and OptiPlex 3090 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                          09-12-2024, 03:44 PM
                          09-12-2024, 03:36 PM
